06-13-2017, 06:13 AM
(06-11-2017 01:39 AM)DavidM Wrote: [ -> ](06-11-2017 12:21 AM)ttw Wrote: [ -> ]Third, one could use a very long cycle generator. The error from lack divisibility does decrease with cycle length. This is probably the most practical solution.
What are your thoughts on the XORSHIFT+ PRNG that John brought up earlier? Does this have a long enough cycle for a practical use on calculator-based apps?
(06-11-2017 12:21 AM)ttw Wrote: [ -> ]Fourth, one could use a simple RNG and not worry about the error. This I probably the most common solution.
I have no data to back this up, but I'd be willing to bet that the "RAND n * CEIL" approach is used far more frequently than any other in calculator programs. Has this actually caused problems for anyone? I suspect we'll never really know.
The XOR+Shift and the linear congruential and the Fibonacci and other generators are all good enough in most cases if the cycle and wordlength is long enough. I posted 64-bit parameters for the congruential and shift register generators somewhere on this board. (If the same length, these can be XORed together to get a longer cycle; if different lengths, either + or - is needed.) Or one could combine generators like cryptographic machines do. For games one needs good precision and very high unpredictability; for Monte Carlo, one needs high precision and cycle but can be predictable.
I have a new type that I'm testing, but I have only empirical evidence that it works. When I've done a bit more testing (ok, several bits), I'll post the method.
