05-30-2017, 02:36 PM
Hello, the next numerical code, I want to run it in HOME MODE.
The definition v(t) does not allow me to define it within the code, Why?
Source: NUMERICAL METHODS FOR ENGINEERS Steven C. Chapra & Raymond P. Canale
![[Image: paracaid.png]](http://1.bp.blogspot.com/_9nuYp5O0gmw/S-q18ZqD3kI/AAAAAAAAABo/JKME697iG5M/s1600/paracaid.png)
I managed to run it by doing the following trick.
Icomment the line // v(t):= vi+(g-(c/m)*vi)*(t-ti);
and I put in the line of entry (CAS MODE) the expression
v(t):= vi + (g- (c / m) * vi) * (t-ti);
euler() returns [] =(
but
[shift][1](program editor) euler
[DEBUG][CONT] [enter] ...[enter] ... ok
The program shows me screen by screen what I want
vi=0 m/s, ti=0 s , tf=0 s
v(0) = 0 m/s
vi=0, ti=0, tf=2
v(2) = 19.62 m/s
vi=19.62 m/s, ti=2 s, tf=4 s
v(4) = 32.04 m/s
vi=32.04 m/s, ti=4 s, tf=6 s
v(6") = 39.90 m/s
Please someone can help me by rewriting the above code to work well
Thanks
PS: In CAS mode if it works fine but how can I clean each screen? The print; command does not seem to be working. I have to clean each screen because the terminal view does not progress after the first impression screen is completed, (even hp-prime is a single process) should allow split screen and more of a process as did the hp48,
Debug mode does not work for CAS MODE = (, for this reason I want to create it in HOME MODE
PHP Code:
// file euler.hppprgm
export euler()
local g,c,m,t;
local vi,ti,vf,tf,iteration;
//local v;
purge(g,c,m,t,vi,ti,vf,tf);
g:=9.81; c:=12.5; m:=68.1;
vi:=0;
ti:=0;
iteration:=1;
print; // clear terminal view (output)
print("euler");
print("press [↓] for next iteration" );
print("press [on] for exit" );
wait(1);
FOR tf FROM 0 TO 10 STEP 2 DO
print("iteration = "+iteration);
vf:=v(tf);
print("vi = "+vi+" m/s");
print("ti = "+ti+" s");
print("tf = "+tf+" s");
print("vf("+tf+") = "+vf+" m/s");
print("");
vi:=vf;
ti:=tf;
iteration:=iteration+1;
wait();
print("Iterations finished," );
return("Done");
but
v(0) = 0 m/s
vi=0, ti=0, tf=2
v(2) = 19.62 m/s
v(4) = 32.04 m/s
v(6") = 39.90 m/s
Thanks
PHP Code:
// file euler1.hppprgm
// version simple MODO CAS
#cas
euler1():=
local g,c,m,t;
local v;
vi:=0;
ti:=0;
iteration:=1;
PRINT(); // clear terminal view (output)
print("euler1");
wait(1);
vf:=v(tf);
print("");
vi:=vf;
ti:=tf;
wait();
print("Iterations finished" );
return("Done");
#end
