05-28-2017, 05:35 PM
A long (long!) time ago I was working on a program to print from my HP 50g to a HP 990cxi inkjet printer though the printer's IRDA interface. Upon moving to a new house some dude placed the printer upside down, ruining it. So, the programming was cancelled as well.
I recently found some of the input form files, so, I'll post them here before I loose them. I tried to use graphics and text input as self-explanatory as posible, incorporating the data entry inside the graphic itself. Nothing fancy, but pretty. I hope someone here has some use for these examples.
First, the page configuration form:
[attachment=4840]
This is the simpler font selection form:
[attachment=4841]
NOTE: the GROB definitions must be continuous, no line breaks.
These are in System RPL. Assemble and EVAL (run)...
[attachment=4840]
%%HP: T(3)A(R)F(.);
"!NO CODE
!RPL
* Label definitions
GROB 0014E B1000F2000FFFFFFFFFF70100800000042108C10080047100800000042108800080042100800000042108800080042100C10000042108800080042555555555552108800080042100C1000004250A800082052FF780000FF7250A80008205210080000004210880008004210080000004210880008004210080000004210880008004210080000004230C800080042CC3B00C10730030C1C3EC8020000E3003000000000000002
(Page grob) 0 15
\"Margins\" 8 9
\"Lines/inch\->\" 0 42
\"Paper Size:\" 64 9
\"Orientation:\" 64 25
\"Perf.skip mode?\" 72 41
* Paper size field
'DROPFALSE (Message handler)
72 17 58 6 (Position & size)
BINT12 (Fld type: choose)
MINUSONE (Types allowed)
BINT1 (Decomp as sm font)
(Help text)
\"Paper size installed in printer \"
{ \"Letter 8.5*11\\\"\"
\"Legal 8.5*14\\\"\"
\"A10 x*y\"
\"Executive x*y\"
} (Options)
BINT1 (ChooseDecomp, ignored)
\"Letter 8.5*11\\\"\" (Initial value)
DUP (Reset value)
* Lines/inch field
48 41 8 6 (Position & size)
BINT3 (Fld type: combo)
{ 0 } (Types allowed)
BINT3 (Decomp as sm font)
(Help text)
\"Number of lines per inch\"
{ % 6 % 8
} (Options)
BINT5 (ChooseDecomp, ignored)
% 6 (Initial value)
DUP (Reset value)
* Top margin field
19 17 8 6 (Position & size)
(Help text)
\"Number of lines for top margin\"
{ % 6 % 8
} (Options)
% 8 (Initial value)
DUP (Reset value)
* Left margin field
3 32 8 6 (Position & size)
BINT5 (Decomp as sm font)
(Help text)
\"Column number for left margin\"
{ % 6 % 8
} (Options)
% 6 (Initial value)
DUP (Reset value)
* Text area field
19 32 12 6 (Position & size)
(Help text)
\"# of lines, text (writable) area\"
{ % 6 % 8
} (Options)
% 52 (Initial value)
DUP (Reset value)
* Right margin field
34 32 8 6 (Position & size)
(Help text)
\"Column number for right margin\"
{ % 6 % 8
} (Options)
% 8 (Initial value)
DUP (Reset value)
* Page area field
48 32 12 6 (Position & size)
(Help text)
\"# of lines for logical page area\"
{ % 6 % 8
} (Options)
% 66 (Initial value)
DUP (Reset value)
* Orientation field
72 32 36 6 (Position & size)
(Help text)
\"Physical page orientation\"
{ \"Portrait\" \"Landscape\"
} (Options)
\"Portrait\" (Initial value)
DUP (Reset value)
* Perforation skip field
65 41 ZEROZERO (Position & size)
BINT32 (Fld type: check)
DUP (Decomp: n/a )
(Help text)
\"Load paper if txt overflows\"
MINUSONE (Options)
DUP (ChooseDecomp, ignored)
TrueTrue (Initial & Reset value)
* xHALT
6 9 (Labels & fields)
'DROPFALSE
\"hp 990Cxi Page Setup\"
FPTR2 ^IfMain
[attachment=4841]
%%HP: T(3)A(R)F(.);
"!NO CODE
!RPL
* Label definitions:
GROB 0013C 900003800020000000000000000000000000000000201000000000000000000000000000000040200000000000000000000000000000002010000000000000000000000000000000402000000000000000000000000000000020100000000000000000000000000000004020000000000000000000000000000000205555555555555555555555555555555550AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA20
(TitleBar ext GROB) 0 7
\"Character set:\" 4 8
\"Spacing:\" 1 19
\"\019\002\019Italic\019\002\019\" 77 19
GROB 00028 500002100070C020BCC83076DC20B6DC207C8930
(Bold label GROB) 112 19
\"Typeface:\" 1 30
\"Pitch:\" 1 41
\"Point Size:\" 60 41
* Field definitions:
* TitleBar extention GROB: n/a
* Character set field
'DROPFALSE (Msg handler)
62 8 67 6 (Pos & size)
BINT12 (Fld type: chs)
MINUSONE (Types, n/a here)
BINT17 (Dcomp sm font)
(Help text)
\"Select character set\"
{ { \"ECMA-94 Latin 1\" \"\027(0N\" }
{ \"PC-8\" \"\027(10N)\" }
{ \"hp Roman-8\" \"\027(8U\" }
{ \"ANSI ASCII\" \"\027(0U)\" }
} (Options)
BINT1 (ChsDcmp,ignored)
(Initial value)
DUP (Reset value)
* Spacing field
(Msg handler, pushed to stack)
5 OVER#=case ::
DROP (Drop msg bint)
DUP
{ \"Proportional\" \"\027(s1P\" }
EQUALcase
(If so, hide Pitch fld...)
5 TrueFalse
FPTR2 ^IfSetFieldVisible
(... & hide Pitch: lbl)
6 FalseFalse
\"Review Size,\\0A please.\"
(ROMPTR 151 B=xStErr)
$>grobCR
ROMPTR B0 86
BINT14
BINT131
MAKEGROB
SWAPOVER
#ZERO#ONE
GROB!
SWAPOVER
BINT11
BINT1
GROB!
PTR 2F3CF
SWAPOVER
ZEROZERO
GROB!
PTR 2F3D0
SetDA1Temp
ERRBEEP
DispStsBound
TRUE (Required)
ClrDAsOK
(Else, unhide Pitch fld & lbl)
5 TrueTrue
6 FalseTrue
TRUE
1 OVER#=case ::
?DispStatus (Clear warnings)
DROPTRUE
DROPFALSE
; (End of msghndlr)
34 19 32 6 (Pos & size)
BINT12 (Fld type: Chs)
BINT17 (Dcmp: sm font)
(Help text)
\"Type of spacing between chars.\"
(Choose options)
{ { \"Fixed\" \"\027(s0P)\" }
(Initial value)
DUP (Reset value)
* Pitch field
26 40 30 8 (Pos. & size)
BINT2 (Fld type: cmb)
{ 0 } (Types, n/a here)
BINT4 (Dcmp sm font)
(Help text)
\"Fixed font's Characters per inch\"
{ %7 %9 %11
} (Options)
BINT4 (ChsDcmp,ignored)
%11 DUP (Initial & reset)
* Point size field
105 40 25 8 (Pos. & size)
(Help text)
\"Fixed font's point size\"
{ %6 %8 %10 %12
} (Options)
%12 DUP (Initial & reset)
* Italic field (Style)
70 19 ZEROZERO (Pos & size)
BINT32 (Fld type: chk)
DUP (Dcmp n/A)
(Help text)
\"Italic font style?\"
MINUSONE (Opts, n/a)
DUP (ChsDcmp,ignored)
FalseFalse (Init&reset values)
* Bold field (Weight)
105 19 ZEROZERO (Pos. & size)
DUP (Dcmp N/A)
(Help text)
\"Bold font weight?\"
FalseFalse (Initial & reset)
* Typeface field
40 29 90 8 (Pos. & size)
BINT16 (Dcmp sm font)
(Help text)
\"Select typeface\"
{ { \"Courier\" \"\027(s3T\" }
{ \"CG Times\" \"\027s4101T\" }
{ \"Letter Gothic\" \"\027(s6T\" }
{ \"Univers\" \"\027(s52T\" }
} (Options)
BINT0 (ChsDcmp,ignored)
(Initial & reset)
{ \"Courier\" \"\027(s3T\" } DUP
* Print Quality: in other form
* Form parameters
8 7 (Lbls & flds)
' :: (Form msghndlr)
7 (IfMsgSetFirstField)
OVER#=case ::
2DROP 6 (Typeface field)
TRUE
DROPFALSE
(Title)
\"hp 990Cxi Printer Setup\"
FPTR2 ^IfMain
