05-27-2017, 09:09 PM
05-28-2017, 04:32 AM
Upgrading Prime's firmware via cable from another Prime is not supported at this time. Anybody know if Prime can be upgraded via wifi from the Classroom Manager?
05-29-2017, 04:44 AM
If it has one of the latest firmware installed, then it can...
I have tested it once and it does work...
However, it is rather slow!
Wifi tops at around 20Kb/s with one calculator connected to the "network"... and around 34MB need to be downloaded (ok, it's compressed to around 8MB), but this is still relatively slow...
If there is a PC in the classroom with the con kit installed, you might as well connect directly with a USB cable and get 200~300KB/s download rate which will do the updated in less than 1 minute.
Cyrille
Cyrille
