04-30-2017, 09:54 AM
The following command gives a wrong output in HOME (FW 10637, VC 11226):
[i, -i] .^ (-1) → [1-i, 1+i]
In CAS you get the correct answer:
[i, -i] .^ (-1) → [-i, i]
If you use lists instead of vectors, you get the correct result both in HOME and CAS:
{i, -i} .^ (-1) → {-i, i}
