04-23-2017, 01:40 PM
Warning, doing the following may cause your handheld to keep resetting itself, it did mine:
1. Press Apps
1. Navigate to the Spreadsheet app
2. Tap Reset, then OK, then Start
3. In cells A1, A2, and A3 type some numbers, say 1,2,3
4. Tap to select Column A and give it a name, type DOG then Tap Name
5. Press Apps, Tap Save, Tap Edit, give it a name, say Spreadsheet2, Tap OK twice
6. Go back to the first Spreadsheet app and Tap Start
7. Tap to select Column B
8. Press Vars, navigate to and tap Spreadsheet2, tap Cell, tap DOG, tap OK
Instead of the expected 1,2,3 you will get 2,3,1,1,1,1,1,1,1, … as far down as you care to scroll. Also the 1's are funny; they appear in the cells but click on one and it doesn't appear in the edit line and the edit soft key doesn't appear, but when you reference a cell (type =B4 in cell C1) you get a 1.
1. Press Apps
