Why can't i add or subtract from values with units?
Ex. I have 8_m on the stack and i want to add one minute.
Also i can not add two temperatures even with corresponding units?
Could it be because _m is meter and _min is minute?
(04-05-2017 04:45 PM)KeithB Wrote: [ -> ]Could it be because _m is meter and _min is minute?
You're right about the wrong unit but the problem remains the same. If i have 8_min and want to add 1 more do i really have to set the unit before adding?
Yes, you do. It is all tied up with the Prime concept of a measurement.
Pretend you are the calculator, you see 4_min + 3
What do you do? Should you assume that 3 is minutes and add them? Use a default time unit of fortnights and add that? Give an error saying that you don't have enough info to solve the problem?
1 and 3 are probably the most reasonable, the Prime chooses 3. If you don't want to use units, leave them off. If you want to work with them, they are required.
(04-05-2017 05:43 PM)KeithB Wrote: [ -> ]Yes, you do. It is all tied up with the Prime concept of a measurement.
Ok, it's just that this was never an issue with the 50g. How do i easily remove units from a value if i don't want to continue with units?
Also, why won't it add 2 temperatures when they're both including the unit?
Because it makes no physical sense.
Adding Kelvin temperatures is allowed.
(04-05-2017 06:21 PM)tdh79 Wrote: [ -> ]Also, why won't it add 2 temperatures when they're both including the unit?
This comes up quite often. Here's an example of why adding temperatures does not make too much sense.
1°C + 1°C = 2°C
However, if we convert to an absolute scale and do:
1°C + 1°C = 274.15K + 274.15K = 548.3K = 275.15°C
Clearly 2°C is not the same as 275.15°C.
Almost all physical units have the common minimal value of 0. (For example, 0 degrees is the same as 0 radians, which is also the same as 0 gradians. And 0 meters is the same as 0 inches, or 0 feet, etc.) However, 0°C is not the same as 0°F, and neither are equal to 0K. This is why adding Kelvin temperatures is not a problem (it is an absolute scale with no temperature less than 0) but it will not work for °C or °F. The same can be said for scalar multiplication of a unit. Multiplication by scalars only make sense if there is some fixed notion of "0" -- there is no fixed "0" for the various temperature units.
That said, if one of the two temperatures is a change in temperature, then the sum makes sense. But even then, the use of mixed units still requires a lot of care on the part of the user (which can be avoided by converting to Kelvin).
(04-05-2017 06:34 PM)KeithB Wrote: [ -> ]Because it makes no physical sense.
But I
want to add 3 degrees Fahrenheit to 20 degrees Celsius to come up with a total of 18 meters, 4.7 inches.
Tom L
"If God had wanted us to use the Metric system, Jesus would've had 10 apostles"
(04-05-2017 06:21 PM)tdh79 Wrote: [ -> ]Ok, it's just that this was never an issue with the 50g.
I think you are remembering wrong. Trying to add 1_m and 1 returns an error.
(04-05-2017 07:58 PM)Tim Wessman Wrote: [ -> ] (04-05-2017 06:21 PM)tdh79 Wrote: [ -> ]Ok, it's just that this was never an issue with the 50g.
You're right, adding two values in Celsius however worked fine..
But I can see why it doesn't make that much sense by the post by Han.
>> add 1 to 3_m
This hits into one of the major issue between math and computer science, human language and computers.
Both math and human language are littered with non explicit-ed, contextually shared assumptions/understanding and loosely defined "items" (sometimes, even symbols/words like plus or minus have different meanings than the basic addition/subtraction ones)
In the (rare) cases where there is a possible misunderstanding, then we see human using convoluted sentences to explicit their words...
Unfortunately, the calculator does not have enough IA to deduce these "non explicit-ed, contextually shared assumptions/understanding" which would allow it to deduce what is meant by a user. It therefore forces you, the user, to explicitly state them, at the cost of extra typing time...
One of the best example is users entering in the graphing app:
F1(X)=sin(X)
F2(X)=dF1(X)/dX
and not understanding why it does not work...
Now, this is such a quintessentially American statement that I had to clean all the coffee from my screen after reading it!
Cyrille
"How do i easily remove units from a value if i don't want to continue with units?"
Well, you can divide the value with units by 1_unit, e.g. 10_m/1_m=10.
My personal notice: Being chemist I also don't know how to calculate the example posted above- 4_min + 3. I used units for all values during my exams and calculations. If I forgot unit the teacher marked this mistake with explanation: How do I know what did you mean.
(04-05-2017 08:09 PM)tdh79 Wrote: [ -> ]You're right, adding two values in Celsius however worked fine..
If you want to expand on Han's answer, there was a deeper discussion of temperature units not too long ago in the following thread:
http://www.hpmuseum.org/forum/thread-4783.html
