03-31-2017, 02:12 PM
Hello, the HP-Prime dialog boxes (a tutorial with all possible combinations of the INPUT command) are superior to the TI68K calcs/1995
http://www.hpmuseum.org/forum/thread-783...ight=INPUT
Only need to complete it with TOOLBAR CMD, an example of code in TI-BASIC, (each function of each ITEM is called by means of a LABEL: ) is required in addition to enclosing the TOOLBAR inside a block LOOP, and each label at the end must return to the LOOP ( With the CYCLE command), there must be at least one label that lets exit (EXIT).
© == commentary
TI68K CODE
![[Image: toolBar_hp_prime_image00a.png]](http://eonicasys.com.co/public/math/CAS/hp_prime/toolBar/images/toolBar_hp_prime_image00a.png)
![[Image: toolBar_hp_prime_image00.png]](http://eonicasys.com.co/public/math/CAS/hp_prime/toolBar/images/toolBar_hp_prime_image00.png)
I think that in the HP-Prime format (list of lists) would be much easier to code
1: Is important for you a TOOLBAR CMD built-in the firmware?
2: What better syntax do you propose? List lists or TI68k style
© == commentary
TI68K CODE
PHP Code:
GUIPOLYH()
Prgm
© animTbar(): Animations Toolbar
Local chspolvl
Loop
Toolbar
Title "Polyhedron"
Item "Regular Polyhedron",regpollb
© regular, convex polyhedron with congruent faces of regular polygons
Item "Other important polyhedra",othrpolb
Title "Paramts"
Item "Set parameters page1/2",wparamlb
Item "Parameters page2/2",wparm2lb
Item "Default values",dftparlb
Item "Print parameters",prtparlb
Title "MakeImag",makeimlb
Title "Animation",startalb
Title "Delete Images"
Item "All",delalllb
Item "Current",delcrrlb
Title "Quit"
Item "Exit without del. images",quit2lb
Item "Delete All Images",quit1lb
Item "Stop",haltlb
Title "About",aboutlb
EndTBar
Cycle © goto Loop
Lbl regpollb:
If polytype≤2 Then
polytype→chspolvl
EndIf
PopUp {"Tetrahedron. 4 Faces","Hexahedron (Cube). 6 Faces","Octahedron. 8 Faces","Dodecahedron 12 Faces","Icosahedron. 20 Faces"},chspolvl
If chspolvl=1 Then
0→chspolvl
Dialog
Text "Tetrahedron is one kind of pyramid"
Text "composed of 4 triangular faces."
EndDlog
poltype(1)
ElseIf chspolvl=2 Then
0→chspolvl
Dialog
Text "A cube is a hexahedron with all"
Text "its faces square and three squares"
Text "around each vertex."
EndDlog
poltype(2)
ElseIf chspolvl=3 Then
0→chspolvl
poltype(3)
ElseIf chspolvl≥4 and chspolvl≤5 Then
0→chspolvl
Dialog
Text "Algorithms still not created,"
Text "will be included in future releases."
EndDlog
EndIf
Cycle © goto Loop
Lbl othrpolb
If polytype≥6 Then
polytype-5→chspolvl
EndIf
PopUp {"Square Pyramid. 5 Faces","Triangular Prism. 6 Faces"},chspolvl
If chspolvl=1 Then
0→chspolvl
Dialog
Text "Square Pyramid is a pyramid, "
Text "having a square base"
EndDlog
poltype(6)
Else
If chspolvl=2 Then
0→chspolvl
poltype(7)
EndIf
EndIf
Cycle © goto Loop
Lbl wparamlb:wparamts()
Cycle © goto Loop
Lbl wparm2lb:wparamt2()
wparm2lb
Cycle © goto Loop
Lbl wparm3lb:wparamt3()
wparm3lb
Cycle © goto Loop
Lbl prtparlb: kernel2\printtxt(prtparm(),0,1,1,1)
Cycle
Lbl dftparlb:dftvalue()
Cycle
Lbl makeimlb:makepict(nimages,highpoly,dcrhigvl,hidedgvl,rotatnvl,axesflag,vertexfl,polytype)
Cycle © goto Loop
Lbl startalb:exeanimt(nimages,anidelay,maxcycle,rotatnvl)
Cycle © goto Loop
Lbl delalllb:delpics(nimages,1)
Cycle © goto Loop
Lbl delcrrlb:delpics(nimages,2)
Cycle © goto Loop
Lbl aboutlb:aniintro()
Cycle © goto Loop
Lbl quit1lb:exitprgm(nimages,1)
Exit © to EndLoop
Lbl quit2lb:exitprgm(nimages,0)
Exit © to EndLoop
Lbl haltlb:Stop
Exit © to EndLoop
EndLoop
EndPrgm
PHP Code:
toolbar(
{ "Menu1 name"/icon, "Title Name M1" {{ "Tag1M1 name" function1T1/{function1T1,function2T1,...} }, { "Tag2M1 name " function1T2/{function1T2,function2T2,...} }, ... } },
{ "Menu2 name"/icon, "Title Name M2" {{ "Tag1M2 name" function1T1/{function1T1,function2T1,...} }, { "Tag2M2 name " function1T2/{function1T2,function2T2,...} }, ... } },
{ "Menu1 name"/icon, "Title Name M6" {{ "Tag1M6 name" function1T1/{function1T1,function2T1,...} }, { "Tag2M6 name " function1T2/{function1T2,function2T2,...} }, ... } },
