//Variables...
t;rh;
hi;hi2;tmp;
// Subroutine...
HeatIndexCalc();
EXPORT HeatIndex()
VIEW "Start HeatIndex",START()
STARTVIEW(-1,1);
WHILE GETKEY<>4 DO
REPEAT
tmp:=INPUT(
{{t,[0],{60,22,1}},
{rh,[0],{60,22,2}},
{hi,[0],{60,22,4}},
{hi2,[0],{60,22,5}}},
"Heat Index Input and Output",
{"Temperature, Deg F : ",
"Relative Humidity, % : ",
"Heat Index, Deg F :",
"Heat Index, Deg F :"},
{" Air Temperature (80 to 104 °F)",
" Relative Humidity (40 to 100 %)",
" Heat Index from www.weatherimages.org",
" Heat Index from www.4wx.com"},
{t,rh,hi,hi2},{t,rh,hi,hi2});
IF tmp==0 THEN
STARTVIEW(-4,1);
MSGBOX("End of Program");
RETURN;
UNTIL t>=80. AND t<=104. AND rh>=40. AND rh<=100.;
HeatIndexCalc();
END; // While
STARTVIEW(-4,1);
HeatIndexCalc()
// This is the 16 element equation used to convert
// dry bulb temperature (T) and relative humidity (RH)
// into the Heat Index. This equation works at
// dry bulb temperatures of 70°F and higher.
// Source: http://www.weatherimages.org/data/heatindex.html
// Where:
// hi = Heat Index
// t = Temperature (° F)
// rh = Relative Humidity (%)
tmp:=16.923;
tmp:=tmp+1.85212*10^(-1)*t;
tmp:=tmp+5.37941*rh;
tmp:=tmp-1.00254*10^(-1)*t*rh;
tmp:=tmp+9.41695*10^(-3)*t^2;
tmp:=tmp+7.28898*10^(-3)*rh^2;
tmp:=tmp+3.45372*10^(-4)*t^2*rh;
tmp:=tmp-8.14971*10^(-4)*t*rh^2;
tmp:=tmp+1.02102*10^(-5)*t^2*rh^2;
tmp:=tmp-3.8646*10^(-5)*t^3;
tmp:=tmp+2.91583*10^(-5)*rh^3;
tmp:=tmp+1.42721*10^(-6)*t^3*rh;
tmp:=tmp+1.97483*10^(-7)*t*rh^3;
tmp:=tmp-2.18429*10^(-8)*t^3*rh^2;
tmp:=tmp+8.43296*10^(-10)*t^2*rh^3;
hi:=tmp-4.81975*10^(-11)*t^3*rh^3;
hi:=ROUND(hi,0);
// Source: http://www.4wx.com/wxcalc/formulas/heatIndex.php
tmp:=-42.379;
tmp:=tmp+2.04901523*t;
tmp:=tmp+10.14333127*rh;
tmp:=tmp-.22475541*t*rh;
tmp:=tmp-6.83783*10^(-3)*t^2;
tmp:=tmp-5.481717*10^(-2)*rh^2;
tmp:=tmp+1.22874*10^(-3)*t^2*rh;
tmp:=tmp+8.5282*10^(-4)*t*rh^2;
hi2:=tmp-1.99*10^(-6)*t^2*rh^2;
hi2:=ROUND(hi2,0);
