Hello
for some time I have randomly collected various old HPIB equipment that was thrown out in various locations that I would like to connect to my HP71b.
I do have a HP-IL/HP-IB interface 82169A connected to my HP71b
But I cant seem to get it to work
I have a Thinkjet 2225A HPIB printer and a HP9122S HPIB disk drive
I never worked with HPIB so I am not familiar with how it works, I do know that I need to set the address jumpers on the back and I set "1" on both units, I only connect one at the time to the 82169A for the moment.
I have tried to read both the HPIL manual and the 82169A manual but I cant understand how to interface them with each other.
If I do
RESTORE IO
it passes so communication with 82169A is good
but If I do
PRINTER IS :PRINTER
I get:
HPIL ERR:Device not found
But as I understand it this command is for the HPIL printer and not the HPIB
I think I need to initialize the printer in some way so that the 82169A knows what address the printer is on but I cant seem to find how to
the same with the HP9122S no luck at all
I might be missing some information how to do this, I have tried to read all manuals I could find about the subject but as I said, I have never worked with HPIB or HPIL
It would be nice to be able to save data from my HP71b on a diskette and to be able to print stuff and perhaps connect it to my oscilloscope and multimeter and various instruments.
I do actually have two HP71b with HPIL interfaces, is it possible to transfer data between these units with the HPIL interface?
Assuming you only have the HP-82169A on the HP-IL loop
and the HP-2225A on the HP-IB interface.
HP-82169A dip switch setting should be (from left to right) "0 0 0 0 0 1"
Leftmost digit: 0 = Translator / 1 = Mailbox -> here 0
Next 5 digits: address (0..31) -> here 00001 = 1
HP-2225A -> Dip switch 0..7 should be (from left to right) "1 0 0 0 0 0 1 0"
Pos 0 : SRQ Enable -> 1 = ON
Pos 1 : Listen Always -> 0 = OFF
Pos 2..7 : address (0..31) -> here 00010 = 2
Power up everything, on the HP-71B
RESET HPIL (optional)
RESTORE IO
PRINTER IS :2
At that point the printer should be ready, use PRINT or PLIST to test it.
Sylvain
Yes it works!
PRINT works now, but Im missing a few lines in the text, a check and cleaning of the printer head shows some corrosion unfortunately.
Well I might repair it if I get the time, or I can try to get some pens for my HP7470A.
I still need to get my HP9122S to work
MASSMEM IS :2 does not work, neither does INITIALIZE DISK:MASSMEM
(03-26-2017 12:40 AM)Adalin Wrote: [ -> ]I still need to get my HP9122S to work
The 9122S drive uses the SS/80 command protocol, which is not supported by the '71 HP-IL, and likely no other HP-IL controllers, including the HP-110 and HP-110+, which use the Amigo (and Filbert) protocols. The 9121 drive uses Amigo, so it's possible that could work if you have one.
(03-26-2017 12:40 AM)Adalin Wrote: [ -> ]Well I might repair it if I get the time, or I can try to get some pens for my HP7470A.
I can confirm that the HP-7470A HP-IB version also work.
Be aware that the plotter only understand HP-GL commands and that you will need to write BASIC programs in order to use it with the HP-71B.
The HP-41/71/75 only support Filbert protocol.
The HP-9122S only support SS/80 protocol.
The HP-9114A/B support both SS/80 and Filbert protocols.
Subset/80 (SS/80) Protocol Document
Sylvain
(03-26-2017 01:16 AM)Sylvain Cote Wrote: [ -> ]The HP-9114A/B support both SS/80 and Filbert protocols.
9114 Supports SS/80? Are you sure? I thought it only supported Filbert and Amigo. Where did you find docs that SS/80 is supported?
(03-26-2017 01:06 AM)rprosperi Wrote: [ -> ] (03-26-2017 12:40 AM)Adalin Wrote: [ -> ]I still need to get my HP9122S to work
From the 9114A CE Handbook:
The HP 9114A Drive supports both the SUBSET/80 and the FILBERT
command set. FILBERT is the command set used by the 82161A
Cassette Tape Drive.
The 110, 110+, and 9114 all support SS/80.
https://groups.io/g/hpseries80/wiki/HP-8...ory-layout
Controller Amigo Filbert SS/80, CS/80
HP 110, 110+ - Filbert SS/80
HP 110, 110+, AMIGO.SYS Amigo Filbert SS/80
HP-41, HP-IL module - Filbert -
HP-71B, HP-IL module - Filbert -
HP-75C/D - Filbert -
Series-80, HP-IB I/F, MS-ROM Amigo - -
Series-80, HP-IB I/F, MS+EMS-ROM Amigo - SS/80
Series-80, HP-IL I/F - - -
HP Integral PC, HP-IB I/F - - SS/80
Peripheral Amigo Filbert SS/80, CS/80
9114A/B - Filbert SS/80
82161A Cassette Drive - Filbert -
most HP-IB Drives (e.g. 9133D) - - SS/80
some HP-IB Drives (e.g. 9133XV) Amigo - -
ILPer/pyILPER Emulators - Filbert -
(03-26-2017 02:08 AM)rprosperi Wrote: [ -> ] (03-26-2017 01:16 AM)Sylvain Cote Wrote: [ -> ]The HP-9114A/B support both SS/80 and Filbert protocols.
You can look at this document:
mass storage for the HP Portable.
Amigo is supported too by manually adding the right device in CONFIG.SYS.
J-F
Wow, refuted in stereo!
(03-26-2017 03:21 AM)Dave Frederickson Wrote: [ -> ]The 110, 110+, and 9114 all support SS/80.
(03-26-2017 09:00 AM)J-F Garnier Wrote: [ -> ]You can look at this document: mass storage for the HP Portable.
So, while 9114 and 110/110+ do apparently support SS/80 (SS stands for Sub Set, meaning not the full CS/80 protocol; SS was used on low-end HP drives), I don't think this changes the core answer that a 9122 cannot be accessed from a '71 via HP-IL/HP-IB adapter, at least out of the box.
Should have stuck with the answer and not generalized...
Note however that it appears SS/80 can be emulated using low-level HP-IL commands as I have an HP-75 program listing "CS80 driver for HP-75 <=>HP-IB<=>HP9121 drives" which almost surely has a typo since the 9121 drives use Amigo. Most likely the drive model listed should be 9122.
Due to the different protocols, not all controllers can connect to all devices. For example, the Series 80 needs a Mass Storage ROM to access Amigo drives and the Extended Mass Storage ROM to access SS/80 drives and even with the HP-IL module, the Series 80 can't access a 9114. The 71 and 9121 are one of those combinations that weren't intended to work together.
You can run the built-in diagnostics if you want to test the drive.
aw damn, well I guess I can use it for saving data from something sometime in the future..
Now to the last subject, Is it possible to communicate HP71b - HP71b with HPIL?
Can I use one device as the display from the other unit?
Or can I transfer data from one unit to the other one?
(03-26-2017 05:19 PM)Adalin Wrote: [ -> ]Now to the last subject, Is it possible to communicate HP71b - HP71b with HPIL?
Yes, it's described in the HP-IL Adapter manual; I captured that in this program, long ago:
10 ! PROG TO TAKE A FILE FROM ANOTHER HP-71
20 ! ROBERT PROSPERI 5 MAY 1984
30 ON ERROR GOTO 140
40 INPUT "Source file name? ";S$
50 INPUT "Target file name? ",S$;D$
55 IF D$="" THEN D$=S$
60 CONTROL ON
70 REMOTE :HP71
80 OUTPUT :HP71 ;"CONTROL OFF"
90 OUTPUT :HP71 ;"COPY "&S$&" TO :LOOP"
100 COPY :HP71 TO D$
110 LOCAL
120 DISP "File transferred successfully!"
130 STOP
140 E=ERRN @ E$=ERRM$ @ L=ERRL
150 DISP "Error ";E;" occurred at line ";L
160 DISP E$
170 STOP
180 END
The program is run on '71 A, used to 'take' a file from '71 B.
Steps:
0. Connect machines via HP-IL (other devices can be on the loop)
1. Turn on B
2. Turn on A
3. On B, do RESTORE IO
4. On A, do RESTORE IO
5. On A, RUN FILECOPY
6. Answer the prompts
7. Enjoy
The error handler originally did more, but I removed most of it when it was simplified; now it looks a bit silly, but it works.
The source file can be reasonably complex (FILE1, FILE2:PORT(3), FILE4:MAIN, etc.) but it's possible you could ask for something that chokes it...
Hello
sorry for late answer I have been away on work related travels
But the program works perfectly!
