03-24-2017, 05:11 PM
Hello I'm creating a project that has n files that contain few equal internal names, and the functions are called between them.
Please create the following two files, from the HPP-CK
A: The MAIN files of each file display a text string "NAME FILE MAIN"
prg1.main; [ENTER] RETURNS "prg1 main" // Expected output.
prg2.main; [ENTER] RETURNS "prg2 main" // Expected output.
B: the functionX files of each file show a list that calls the main function of its own file and the other.
prg1.functionX; [ENTER] RETURNS {"prg1 main", "prg2 main"} // Expected output.
prg2.functionX; [ENTER] RETURNS {"prg2 main", "prg1 main"} // Expected output.
FILE1 NAME: prg1
prg1.functionX(); [ENTER] RETURNS "syntax error" // ok because prg2 has not yet been defined.
FILE2 NAME: prg2
prg1.functionX(); [ENTER] RETURNS "syntax error" // Why?
or
prg2.functionX(); [ENTER] RETURNS "syntax error" // Why?
A trick, if you temporarily delete the path, it compiles successfully
-> [SAVE] OK
then rewrite route
-> [SAVE] OK
The two files work fine, but think if there are several definitions, it is very laborious to perform the previous trick.
prg1.main; [ENTER] RETURNS "prg1 main" // ok
prg2.main; [ENTER] RETURNS "prg2 main" // ok
prg1.functionX; [ENTER] RETURNS {"prg1 main", "prg2 main"} // ok
prg2.functionX; [ENTER] RETURNS {"prg2 main", "prg1 main"} // ok
Now If you rename any of the files it is obvious that a syntax error is generated. Because the path is not found
prg2 -> prgM2
prg1.functionX; [ENTER] RETURNS "syntax error" // ok
But if you re-rename with the original names still showing syntax error, Why?
prgM2 -> prg2
prg1.functionX; [ENTER] RETURNS "syntax error" // ?
From this arises the need for two new cmds or headers
#INTERNAL: Internal name, not to depend on the name stored in the calculator or PC
#INCLUDED: File for compilation attached
FILE 1 NAME: 123ABCDEFRFR
FILE 2 NAME: 00000888
I am not the only one that creates independent programs or a single file
http://www.hpmuseum.org/forum/thread-722...ht=libmenu
FILE1 NAME: prg1
PHP Code:
EXPORT main()
return "prg1 main";
EXPORT functionX()
return { main, prg2.main };
//EXPORT ...
FILE2 NAME: prg2
PHP Code:
EXPORT main()
return "prg2 main";
EXPORT functionX()
return { main, prg1.main };
//export ...
or
PHP Code:
PHP Code:
return { main, main };
then rewrite route
PHP Code:
prg2 -> prgM2
prgM2 -> prg2
PHP Code:
#INTERNAL prg1
#INCLUDED prg2
EXPORT main()
return "prg1 main";
EXPORT functionX()
// EXPORT ...
PHP Code:
#INTERNAL prg2
#INCLUDED prg1
EXPORT main()
return "prg2 main";
EXPORT functionX()
//export ...
