Hallo,
How can i make a green Background by a Choose Funktion?
//RECT_P(RGB(154,205,50)); //<-- Problem
CHOOSE(N,"* F L U G N A V I G A T I O N*",{"ICAO-Kennung","Position","Flugstrecke","E N D E"});
IF N==1 THEN ICAO;
//IF N==2 THEN Position;
//END;
IF N==3 THEN Flugstrecke;
//END;
WAIT;
//END;
Like this?
EXPORT clrs()
LOCAL red:=RGB(255,0,0),
green:=RGB(0,255,0),
blue:=RGB(0,0,255);
L0:={"red","green","blue"};
CHOOSE(X,"COLORS",L0);
RECT_P(G0,0,0,320,220,EXPR(L0((X))));
wait(2);
No, i mean i would like the choose funktion on a green background!
It is not possible to place a background on the integrated interfaces such as CHOOSE, MSGBOX, INPUT, EDITMAT, EDITLIST, PRINT.
Okay.
is there another way to make an input with green background?
(03-16-2017 06:04 PM)Onieh Wrote: [ -> ]Okay.
Yes. You can draw everything yourself. And program the whole functionality
PHP Code:
EXPORT popup_problem()
WAIT;
CHOOSE(N,"TITLE",{"A","B","C"}); //<-- Problem (NO POPUP)
WAIT;
The hp48/49/50 series, the dialog boxes (I/O) are displayed in the current screen view, Why the HP-Prime Group did not continue with this form in hp-prime?.
Using the terminal view for example, CHOOSE and others dialog boxes cmds are displayed in the history view (HOME/CAS), I think they should be displayed in the current view as popup and you?
the DRAWMENU cmd work as a popup =), but if each menu calls an MSGBOX OR CHOOSE does not work =(
PHP Code:
EXPORT popup2_problem()
PRINT();
PRINT("INTRO"); WAIT;
PRINT("2"); WAIT;
MSGBOX("TEXT"); //<-- Problem
PRINT("3"); WAIT;
DRAWMENU("MENU1","","MENU2"); //<-- ok
WAIT;
PRINT("4"); WAIT;
The background (HISTORY VIEW) must be controlled by a command similar to LCD-> & TEXT { "History View" « LCD-> ->STR TEXT 1 WAIT 7 » }
...And also for some errors, such as compilation errors, the message popup is displayed outside the current view and in some cases in the history view, It is very uncomfortable to be returning manually to the preview, it should remain in the current
This can be seen in the following gif (
Syntax error)
An example, where CHOOSE DBOX (HP-50) is shown popup
PHP Code:
%%HP: T(0)A(D)F(.);
@ Author: compsystems
@ Version: 1.0
@ Creado con el IDE HPUserEdit 6 (PERU)
DIR
SetBackGround
-90 SF
holdDisplay
DO
"Select Background"
listBackground
posBackground
IF
CHOOSE
THEN
EVAL 'posBackground' STO OBJ-> putGraphicObjCoo00 holdDisplay 2 WAIT
ELSE KILL
END
UNTIL 0
END
listBackground
{ "BlackBackgroundG" « "BlackBackgroundG" 1 » }
{ "PixelBackgroundG" « "PixelBackgroundG" 2 » }
{ "GrideBackgroundG" « "GrideBackgroundG" 3 » }
{ "CircleBackgrondG" « "CircleBackgrondG" 4 » }
{ "Circle2BackgrndG" « "Circle2BackgrndG" 5 » }
{ "FloorBackgroundG" « "FloorBackgroundG" 6 » }
EmptyBackgroundG GROB 131 80 0
BlackBackgroundG « EmptyBackgroundG NEG »
PixelBackgroundG GROB 131 80 55555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000555555555555555555555555555555555000000000000000000000000000000000005555555555555555555555555555555550000000000000000000000000000000000055555555555555555555555555555555500000000000000000000000000000000000
GrideBackgroundG « PixelBackgroundG NEG »
CircleBackgrondG GROB 131 80 6BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B50942942942942942942942942942942942094294294294294294294294294294294206BD6BD6BD6BD6BD6BD6BD6BD6BD6BD6B509429429429429429429429429429429420
Circle2BackgrndG « CircleBackgrondG NEG »
FloorBackground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
putGraphicObjCoo00
PICT { # 0d # 0d } ROT REPL
holdDisplay
{ # 0d # 0d } PVIEW 7 FREEZE
posBackground
1
END
okay, what is with this Solution.
But i don't why the Program leave the Repeat-Until Funktion when i press 111... or 222... or 333...?
EXPORT NewInput()
RECT_P(0,0,320,220,RGB(0,255,0));
TEXTOUT_P("F L U G N A V I G A T I O N",31,20,7,RGB(255,255,255));
TEXTOUT_P("Press 1 für: ICAO",70,70);
TEXTOUT_P("Press 2 für: POSITION",70,100);
TEXTOUT_P("Press 3 für: FLUGSTRECKE",70,130);
TEXTOUT_P("Press Del für Abbruch",70,160);
REPEAT
K:=GETKEY;
IF K==42 THEN PRINT("ICAO"); END; //KEY Test
IF K==43 THEN PRINT("POSITION"); END; //KEY TEST
IF K==44 THEN PRINT("FLUGSTRECKE"); END; //KEY TEST
UNTIL K==19;
STARTVIEW(-1);
