Full Version: problems in INPUT CMD [Matrix editing and symbol expr, ...]
Hello
please copy/paste the following code (HP-P CK) execute, and follow the steps below to check the failures.
PHP Code:
export unitVarstrVar;
export inputTypes()
  local ObjectType_All
:= -1;
local ObjectType_Real := 0;
local ObjectType_Integer := 1;
local ObjectType_String := 2;
local ObjectType_Complex := 3;
local ObjectType_Matrix := 4;
local ObjectType_Error := 5
local ObjectType_List := 6;
local ObjectType_SymbolicExpression := 8;
local ObjectType_Unit := 9
L1 := { 1.5#FFFh, "X \"2\" Y", 3+4*i, "5", [[ 1, 3+4*i ],[ #FFFh, 3°05′06″ ]], { { 'Y=X^2', 'Y=2*X+3' },(5∡53), [ 3,4 ] }, 'X^2^Y^Z^W', 3_m, 3°05′06″, (3,4), "pi+3", 'X' };
if(
input
L1(1), [ ObjectType_Real ] },
L1(2), [ ObjectType_Integer ] },
L1(3), [ ObjectType_String ] },
L1(4), [ ObjectType_Complex ] },
L1(6), [ ObjectType_Matrix ] },
L1(7), [ ObjectType_List ] },
L1(8), [ ObjectType_SymbolicExpression ] },
L1(9), [ ObjectType_Unit ] },
L1(10), [ ObjectType_Real ] },
L1(11), [ ObjectType_Complex ] },
L1(12), [ ObjectType_All ] },
L1(13), [ ObjectType_SymbolicExpressionObjectType_Real ] }
"Data Types page 1/2","Data Types page 2/2" },
"Real:""Binary Integer:""String:""Complex:""Matrix:""List:""SymExpr:""Unit:""Real (Angle)""Complex (x,y)""Any""Real or SymbExpr" },
5/3#10h, char(64), (5∡53), [ e^1, pi/2 ], { {1, 2}, 5 mod 3 }, 'Y=X^2', 3.1_m, 3°, e^1, "e", 'Y' }
then
    A
:=L1(1);
B:=L1(2);
strVar:=L1(3);
Z1:=L1(4);
M1:=L1(6);
L2:=L1(7);
L3:=L1(7,1);
E1:=L3(1);
E2:=L3(2);
F1:=L1(8);
unitVar:=L1(9);
C:=L1(10);
Z2:=L1(11);
IFERR F2:=L1(12);
THEN
    END
IFERR F3:=L1(13);
THEN
    END
    return(
L1);
end;
END
1: in the "SymExpr" (Last field of the first page) or "Matrix" field (field #5) , when editing a matrix or symbolic expression only one line appears, it should be shown in n lines, Otherwise it is very difficult to edit
2: If you enter a data type that does not match the specified type, is deleted from the edit line it must be kept for editing
3: The string ("X \"2\" Y") is displayed as (X ""2"" Y), request Include "" external containers when edit a string object, with the purpose of differentiate from other types of data ("X "2" Y")
4: in the last field "Real or SymbExpr" (second page) , there is a problem, it does not recognize the 2 data types, (symbolic expressions), if you enter 'X^2' -> "Error: Invalid Input"
5: 'X' is evaluated to 0 (Must be enclosed in quotation marks.), Press [shift]+[esc] for reset all values of the second page
All failures? Do you know how to properly use these features as they were designed?
