03-07-2017, 02:25 AM
Usage: COMBOSET(set, size) where set is a set of objects, and size refers to the desired size of the subsets.
Example: COMBOSET({1, "b", (2,-1), [1,2], 3.14}, 3)
{1,"b",2-i},
{1,"b",[1,2]},
{1,"b",3.14},
{1,2-i,[1,2]},
{1,2-i,3.14},
{1,[1,2],3.14},
{"b",2-i,[1,2]},
{"b",2-i,3.14},
{"b",[1,2],3.14},
{2-i,[1,2],3.14}
See also:
http://www.hpmuseum.org/forum/thread-2845.html
http://www.hpmuseum.org/forum/thread-7759.html
{1,"b",2-i},
{1,"b",[1,2]},
{1,"b",3.14},
{1,2-i,[1,2]},
{1,2-i,3.14},
{1,[1,2],3.14},
{"b",2-i,[1,2]},
{"b",2-i,3.14},
{"b",[1,2],3.14},
{2-i,[1,2],3.14}
EXPORT COMBOSET(s,n)
local l:={};
local sl:={};
local tl:={};
local i,j;
local m:=size(s);
n:=IP(n); // ensure n is an integer to avoid infinite loop
case
if n==m then l:={s}; end;
if n==1 then l:=makelist({s(X)},X,1,m); end;
if n>m then l:={}; end;
for i from 2 to m-n+2 do
sl:=sub(s,i,m);
tl:=COMBOSET(sl,n-1);
for j from 1 to size(tl) do
tl(j):=concat({s(i-1)},tl(j));
end;
l:=concat(l,tl);
end;
end;
See also:
