03-04-2017, 05:28 PM
Hello everybody
I am working in a beam dimensioning program that gives a very big list of results (geometrical proprieties of the beam, proprieties of the different materials, curvatures for different bending moments... ) in order to make it practical I decided to print those results with the units and a little explanation using print commands to read the solution on the terminal. the problem is that the program is so long that i loose the first lines of text because the terminal seems to be full. I tried to pause the program using the WAIT command but i can't scroll because in the moment I touch the screen it triggers the rest of the program. Ideas?
