02-24-2017, 05:36 PM
Hello
One way to better visualize a code, where a function has several arguments (for example input( arg1, arg2, ..., argn), is to write each argument in a separate line
input
arg1,
arg2,
argn
But if you want to comment with // the code generates error, because the comment covers until the end of the sentence (; ), for this we need comments of the form / * * /
Successful compilation
But not with
The problem would be solved in the following way
input
arg1,
arg2,
argn
PHP Code:
export testInputList()
begin
local a, b, c;
local resetVAL_a, resetVAL_b, resetVAL_c;
local initVAL_a, initVAL_b, initVAL_c;
initVAL_a:={1}; initVAL_b:={2}; initVAL_c:={3};
resetVAL_a:={}; resetVAL_b:={}; resetVAL_c:={};
local ObjectType_AllAllowed := -1;
local ObjectType_Real := 0;
local ObjectType_Integer := 1;
local ObjectType_String := 2;
local ObjectType_Complex := 3;
local ObjectType_Matrix := 4;
local ObjectType_List := 6;
local ObjectType_Function := 8;
local ObjectType_Unit := 9;
local ObjectType_CAS := 14;
local ObjectType := ObjectType_List;
local title;
case
if ObjectType == -1 then title:="Type Allow: "+"Alls" end;
if ObjectType == 0 then title:="Type Allow: "+"Real" end;
if ObjectType == 1 then title:="Type Allow: "+"Integer" end;
if ObjectType == 2 then title:="Type Allow: "+"String" end;
if ObjectType == 3 then title:="Type Allow: "+"Complex" end;
if ObjectType == 4 then title:="Type Allow: "+"Matrix" end;
if ObjectType == 6 then title:="Type Allow: "+"List" end;
if ObjectType == 8 then title:="Type Allow: "+"Function" end;
if ObjectType == 9 then title:="Type Allow: "+"Unit" end;
if ObjectType == 14 then title:="Type Allow: "+"CAS" end;
default
title:="Type Allow: "+"?"
end;
local ok := 1;
local cancel := 0;
local keyPressedOnMenu := 0;
keyPressedOnMenu := input
{a, [ObjectType] },
{b, [ObjectType] },
{c, [ObjectType] }
title,
{ "label_a", "label_b","label_c" },
{ "help_a", "help_b", "help_c" },
{ resetVAL_a, resetVAL_b, resetVAL_c },
{ initVAL_a, initVAL_b, initVAL_c }
if keyPressedOnMenu == ok then
return ({a, b, c});
else
return "Done";
end;
end;
But not with
PHP Code:
INPUT
//{ resetVAL_a, resetVAL_b, resetVAL_c },
//{ initVAL_a, initVAL_b, initVAL_c }
); // end input
PHP Code:
INPUT
/* { resetVAL_a, resetVAL_b, resetVAL_c }, */
/* { initVAL_a, initVAL_b, initVAL_c } */
