02-22-2017, 01:54 PM
Discrete Fourier Transform with the 41Z Module.
Not much of a groundbreaking algorithm, the program below uses the straightforward definition to obtain the DFT and inverse DFT of a set of N complex data points, stored in complex data registers ZR01 to ZR0n. You can use the sub-function ZINPT from the module to enter all values.
Just enter the sample size in X, and execute ZDFT. The results are stored in complex registers ZRn+1 to ZR(2n). You can use the sub-function ZOUPT to see the values.
If you want to apply the inverse DFT to the results you can use REGSWAP to reset the locations: 2,00(2+2n)00(2n). i.e. 2,010|008 for n=4. Then run ZIDFT to obtain the original values (except rounding).
Example:
DFT [ 1+2i ; 3+4i ; 5+6i ; 7+8i ] = [ 16+20.i ; -8 ; -4-4.i ; -8.i ]
IDFT [ 16+20.i ; -8 ; -4-4.i ; -8.i ] = [ 1+2i ; 3+4i ; 5+6i ; 7+8i ]
As always, the execution time can be rather long for large size samples. Using the 41-CL or an emulator in Turbo mode is recommended.
Feedback is welcome - would be great to get an FFT implementation as well... any volunteers?
Example:
01 LBL "ZDFT"
02 CF 01
03 GTO 02
04 LBL "ZIDFT"
05 SF 01
06 LBL 02
07 STO N
08 E3/E+
09 STO M
10 LBL 01
11 VIEW M
12 CLX
13 STO 00
14 STO 01
15 RCL N
16 E3/E+
17 STO O
18 RCL M
19 INT
20 E
21 -
22 PI
23 *
24 ST+ X
25 RCL N
26 /
27 STO P
28 LBL 00
29 RCL O
30 INT
31 E
32 -
33 RCL P
34 *
35 FC? 01
36 CHS
37 1
38 P-R
39 ZRC* IND O
40 ZST+ 00
41 ISG O
42 GTO 00
43 RCL M
44 INT
45 RCL N
46 +
47 ZRCL 00
48 FC? 01
40 GTO 02
41 RCL N
42 ST/ Z
43 /
44 LBL 02
45 ZSTO IND Z
46 ISG M
47 GTO 01
48 END
