02-19-2017, 10:35 PM
My job was to convert old-style BASIC programs to the Prime's HPPL.
Below is an example from Problems for Computer Solution by Stephen J. Rogowski. It is a classic example of spaghetti code that I converted to work on the Prime. Just so you don't think I'm trying to get someone here to do my work for me, I will post another message with my solution. If you want to do the mental exercise, don't look at the solution post before trying the conversion yourself! That would spoil the fun!
Tom L
Tom L
10 DIM X(126),K(2)
20 DEF FNA(X,Y,Z)=X*SIN(Y*0.01745329)*Z-16*Z^2
30 PRINT "INPUT MUZZLE VELOCITY (FT/SEC) AND ANGLE (DEGREES)"
40 LET F2=0
50 INPUT M,A
60 LET X(0)=0
70 FOR T=0.2 TO 25 STEP 0.2
80 LET L=INT(5*T+0.001)
90 LET X(L)=FNA(M,A,T)
100 IF X(L)<0 THEN GOTO 150
110 IF X(L)-X(L-1)<=0 AND F2=0 THEN GOTO 250 ELSE GOTO 350
120 LET K(1)=X(L-2)
130 LET W4=T-0.4+J
140 GOTO 280
150 LET W=L-1
160 FOR J=0.01 TO 0.2 STEP 0.01
170 LET K(1)=FNA(M,A,T-0.2+J)
180 IF K(1)<0 THEN GOTO 200
190 NEXT J
200 PRINT "MAXIMUM HEIGHT IS ";K1;" FEET"
210 LET Y=M*COS(A*0.01745329)*(T-0.2+J-0.01)
220 PRINT "RANGE IS ";Y;" FEET"
230 PRINT "TOTAL TIME AIRBORNE IS ";T+J-0.01;" SECONDS"
240 GOTO 360
250 IF X(L-1)-X(L-2)<X(L)-X(L-1) THEN GOTO 120
260 LET K(1)=X(L-1)
270 LET W4=T-0.2+J
280 LET F2=1
290 FOR J=0.01 TO 0.2 STEP 0.01
300 LET K(2)=FNA(M,A,W4)
310 IF K(1)-K(2)<=0 THEN GOTO 340
320 LET K(1)=K(2)
330 NEXT J
340 LET K1=MAX(K(1),K(2))
350 NEXT T
360 IF K1+10>60 THEN GOTO 470 ELSE LET M1=1
370 FOR D=1 TO 62
380 PRINT TAB(11);"+";
390 NEXT D
395 PRINT
400 PRINT "0";TAB(11);"+"
410 FOR N=1 TO W
420 PRINT 0.2*N*M*COS(A*0.01745329);TAB(11);"+";TAB(X(N)*M1+11);"*"
430 NEXT N
440 PRINT "ANYMORE (YES OR NO)";
450 INPUT A$
460 IF UCASE$(A$)="YES" THEN GOTO 30 ELSE GOTO 500
470 LET M1=1/(INT(K1/60+1))
480 PRINT "SCALE OF HEIGHT IS 1 SPACE = ";1/M1;" FEET"
490 GOTO 370
500 END
