02-15-2017, 07:59 AM
a.k.a. Solving systems of non-linear equations using the successive approximations method (SAM)... in the complex domain (Z).
Now that we got the long title done and over with, the actual description should be a breeze...
First off, this routine adapts to the 41Z platform the method published by JM Baillard (see here). A few program lines needed changing, mainly to adjust the registers mapping to the convention used by the 41Z. Using 41Z functions also reduced the code size, which is always welcome.
This program includes routines for data entry and output of results - so it's a "driver"of the core routine published in JM's page. This provides a convenient way to use it.
This method requires one equation in explicit form for each of the n-variables, thus n-equations in total as global labels in RAM. The global label names are prompted, as well as n guess (complex) values to start the iterative process. It's not a fast approach, so don't expect blasting speed - yet should be a reliable method with sensible initial guesses.
Using the same example given in the above reference:
z1 = ( z1^2 - z2 )^1/3 ,
z2 = ( z2^2 - z1 )^1/4
programmed as follows:
Using (1+i) as initial guesses for both z1 and z2, the results are obtained in a few seconds on the 41-CL, or with an emulator in Turbo mode.
z1 = R02 + i R03 = 1.038322757 + 0.715596476 i
z2 = R04 + i R05 = 1.041713085 - 0.462002405 i
And here's the program code in all its glorious splendor:-
E3/E+ is of course a shortcut for {1 E3, / , 1, +}
ARCLI 01 is a shortcut for {FIX 0, CF 29, ARCL 01, SF 29, FIX 3}
The updated 41Z_Deluxe module - including the ZSAM program in it is now in the DFT posting.
Happy ZSAM'ing folks!
Cheers,
ÁM
01 LBL "Z1=" 11 LBL "Z2="
02 ZRCL 01 12 ZRCL 02
03 Z^2 13 Z^2
04 ZRCL 02 14 ZRCL 01
05 Z- 15 Z-
06 3 16 4
07 Z^1/X 17 Z^1/X
08 RTN 18 END
01 LBL "ZSAM"
02 SIZE?
03 "N=?"
04 PROMPT
05 STO 00
06 3
07 *
08 E
09 +
10 X>Y?
11 PSIZE
12 XEQ 00
13 RCL 00
14 E3/E+
15 ZINPT
16 LBL 01
17 VIEW 02
18 CLA
19 RCL 00
20 ST+ X
21 STO M
22 LBL 02
23 RCL 00
24 ST+ X
25 E
26 +
27 RCL M
28 +
29 RCL IND X
30 RDN
31 XEQ IND T
32 ZENTER^
33 ZRCL IND M(5)
34 Z-
35 ZMOD
36 ST+ N(6)
37 DSE M(5)
38 GTO 02
39 X<>N
40 E-8
41 RCL 00
42 *
43 X<Y?
44 GTO 01
45 RCL 00
46 E3/E+
47 ZOUPT
48 RTN
49 LBL 00
50 RCL 00
51 ST+ X
52 2.1
53 +
54 STO 02
55 RCL 00
56 E3/E+
57 STO 01
58 AON
59 CF 23
60 LBL 05
61 "F#"
62 ARCLI 01
63 " |-? "
64 ARCL IND 02
65 STOP
66 FS?C 23
67 ASTO IND 02
68 ISG 02
69 ISG 01
70 GTO 05
71 AOFF
72 END
Cheers,
ÁM
