02-25-2014, 11:43 PM
HP Development Team:
For the next release, would it be possible to please re-check uppercase commands in the tool catalog for proper results?
When in CAS mode, there can be problems, e.g. 8 MOD 5 doesn't work.
CAS mode will substitute lower case "mod" into the command line, which then doesn't work. Only if the user erases "mod" and types in "MOD" will this command work in CAS mode.
But in Home, 8 MOD 5 returns 3.
This behavior was documented before with MAKELIST and MAKEMAT (MAKEMAT has difficulties filling a vector in CAS mode, e.g., MAKEMAT(4,8) no-go, but it is fine in Home mode). However, more commands are obviously affected, if they are selected by the user from the tool catalog in CAS mode. Some other uppercase commands are fine, e.g., MIN(7,8,9) - - no problem.
Thanks!
Thanks!
