Full Version: REQUEST: warning messages inside a popup "window"
Hello
The warning messages that launch some CAS commands current are displayed in the TERMNAL view, this "damages" the output of a program =(
The output must be in a popup "popup" window, closed with [ESC]
THE PRINTED OUTPUTS ONLY MUST BE USER, NOT SYSTEM
Try the following script
PHP Code:
#cas
script1():=
begin
    local eq1
eq2solanswer;
      print;
purge(x,y);
      print(
"Find the dimensions of a rectangle whose area is 45 and its perimeter 28");
    print(
    print(
"METHOD 1 (Algebraic solution, stepwise)");
        print(
"Let x = long, y = width");
   print(
        print(
"The equations are:");
eq1:=x*y=45;
    print(
"eq1: "+eq1);
eq2:=2x+2y=28
    print(
"eq2: "+eq2);
    print(
answer:=factor(eq2); // -> (2*(x+y)) = 28
print("factor(eq2): "+answer);
    print(
answer:=answer/2// ->(2*(x+y)/2) = 14
print("Ans/2: "+answer);
answer:=simplify(answer); // -> (x+y) = 14
print("simplify(Ans): "+answer);
    print(
sol:= y=solve(answer,y)[1]; //  y = (-x+14)
print("sol(Ans,y): "+sol);
    print(
answer:= (eq1|sol);
answer:=subst(eq1,sol); //  -> (x*(-x+14)) = 45
print("subst(eq1,answer): "+answer);
answer:=simplify(answer); // -> (-x^2+14*x) = 45
    print(
sol:=solve(answer,x); // -> {5,9}
print("sol(Ans,x): x1,2="+sol);
    print(
    print(
"test solutions");
answer:= (eq1|{x=sol[1], y=sol[2]});
    print(
"eq1: "+answer); // -> 45=45
answer:=evalBool(answer,'=','==');
    print(
"eq1: "+answer); // true
print("");
answer:=(eq2|{x=sol[1], y=sol[2]});
    print(
"eq2: "+answer); // -> 28=28
    print(
"eq2: "+answer);
    return
"Done"
end;
#end
#cas
evalBoolexpr1str1str2 ):=
begin
return( iftesubst(expr1str1str2 ), "TRUE""FALSE") );
end;
#end
[Image: terminalView_warningMessages_imagen00.png]
