Full Version: Testing ANSWER cmd
Hello, the following statements Written on CAS history
print("test ANS cmd");
id0:=0+1;
print("ans1: "+Ans); // ans1: 1
id0:=1+1;
print("ans2: "+Ans); // ans2: 2
id0:=2+1;
print("ans3: "+Ans); // ans3: 3
show in the terminal view
test ANS cmd
ans1: 1
ans2: 2
ans3: 3
But within a program
PHP Code:
#cas
anscmd():=
begin
print;
        print(
"test ANS cmd");
id0:=0+1;
        print(
id0:=1+1;
        print(
id0:=2+1;
        print(
#end
test ANS cmd
ans1: 0
ans2: 0
ans3: 0
Why?
The following CAS code Requires storing each statement in an identifier, and you can not use 'Ans' Cmd =(
PHP Code:
#cas
script1():=
begin
    local eq1
eq2solanswer;
      print;
purge(x,y);
      print(
"Find the dimensions of a rectangle whose area is 45 and its perimeter 28");
    print(
"METHOD 1 (Algebraic solution, stepwise)");
        print(
"Let x = long, y = width");
   print(
        print(
"The equations are:");
eq1:=x*y=45;
    print(
"eq1: "+eq1);
eq2:=2x+2y=28
    print(
"eq2: "+eq2);
    print(
answer:=factor(eq2); // -> (2*(x+y)) = 28
print("factor(eq2): "+answer);
    print(
answer:=answer/2// ->(2*(x+y)/2) = 14
print("Ans/2: "+answer);
answer:=simplify(answer); // -> (x+y) = 14
print("simplify(Ans): "+answer);
    print(
sol:= y=solve(answer,y)[1]; //  y = (-x+14)
print("sol(Ans,y): "+sol);
    print(
//answer:= (eq1|sol);
answer:=subst(eq1,sol); //  -> (x*(-x+14)) = 45
print("subst(eq1,answer): "+answer);
answer:=simplify(answer); // -> (-x^2+14*x) = 45
    print(
sol:=solve(answer,x); // -> {5,9}
print("sol(Ans,x): x1,2="+sol);
    print(
    print(
"test solutions");
answer:=(eq1|{x=sol[1], y=sol[2]});
    print(
"eq1: "+answer);
answer:=evalBool(answer,'=','==');
    print(
"eq1: "+answer);
    print(
answer:=(eq2|{x=sol[1], y=sol[2]});
    print(
"eq2: "+answer);
    print(
"eq2: "+answer);
    return
"Done";
end;
#end
#cas
evalBoolexpr1str1str2 ):=
begin
return( iftesubst(expr1str1str2 ), "TRUE""FALSE") );
end;
#end
I think ANS is a keyboard only thing that is there for convenience. It does not work on my HP71B, either, though that has a much clearer demarcation between "BASIC mode" and "CALC mode".
Though, I really like the () notation to get ans into an equation.
