Full Version: vars, geometry app
Is it possible to change the options of the graphic vars like color, label or visibility, by means of code?
Can be done using Instruction().
Arno
Where I could find documentation about Instruction?
Thanks
(01-22-2017 02:43 AM)fabila Wrote: [ -> ]Where I could find documentation about Instruction?
Thanks
Method 1: Press the Help key, then tap Tree, Search, type "ins" (without the quotes), and press Enter three times.
Method 2: Type "Instruction" on the command line (without quotes), then press the Help key.
At the beginning of the code
STARTAPP("Geometry")
To manipulate the elements directly
