01-17-2017, 12:39 AM
Hello, and thanks for answering, I'm new to the forum so please tell me if this is the wrong sub-forum.
I recently got an HP Prime, I can't believe how simple it is programming it, however I encountered a few problems when creating a UI for input.
I made a program based on style 2 of:
http://www.hpmuseum.org/forum/thread-455.html
The code for my program is:
Basically the same structure, only modified to implement a different numerical method.
The program passes the check.
The problem arises when the program is running; when I try to input the first algebraic function (between simple quotes), I get the message: "Error: Invalid Input", even if I try to input something as simple as a parabola.
Am I doing something wrong?
Is there something my program is missing?
Thanks for your help.
EXPORT PuntoFijo()
local n,xact,xnue,fx,err,N,f,f1;
N:=100; xnue:=1;
if input(
{f,f1,err,xact},
"Metodo del punto fijo",
{"f(X)=", "f(X)=", "Error=", "x0="},
"Ingrese la funcion rodeada por comillas simples",
"Ingrese la funcion depsejada rodeada por comillas simples",
"Ingrese el error maximo",
"Ingrese la raiz aproximada"
{f,f1,err,xact}
) then
F1:=f;
F2:=f1;
M0:={};
M0(n,1):=n;
M0(n,2):=xact;
M0(n,3):=F2(xact);
M0(n,4):=abs(F1(xact));
for n from 2 to N+1 do
xact:=xnue;
xnue:=F2(xact);
fx:=F1(xact);
M0(n,1):=n;
M0(n,2):=xact;
M0(n,3):=xnue;
M0(n,4):=fx;
if abs(fx)<err then break; end;
end;
editMat(M0);
end;
