Full Version: FTN IO API
Some routines that might help parse Fortran-formatted data.
A work in progress that acts as a reminder of what popular formatting codes mean.
Parsing these comprehensively will never be completed, but some of the simpler formats are handled.
Just to be clear...
The aim is that if you read a data file specifying I8, you can call FTN-I(8) to read the number...
Not to parse FORMAT(I8) in the Fortran source.
Version 0.001
 //Fortran IO 2017 StephenG1CMZ
 FTN_FMT_SP(); //FORWARD
 FTN_FMT_SS(); //FORWARD
 LOCAL SP:=" ";
 LOCAL STMINUS:="-";  //IN IO TEXT MAY USE -
 LOCAL STNEGATE:="−"; //WHEN PARSING USE NEGATE PLUSMINUS
 LOCAL STMINUSES:=STMINUS+STNEGATE;
 LOCAL STPLUSES :="+ ";
 //CUSTOMISE
 LOCAL FTN_SIGNALLING_NAN:=0; //
 LOCAL AVOID_IE; //1 0 PREVENT EG 1ᴇ12 ON INTEGER OUT
 //LOCAL STMINUSOUT:=STNEGATE;//USE THIS ON OUTPUT
 LOCAL CHPLUS_DEFAULT:=FTN_FMT_SS(); //_SP  OR _SS
 LOCAL CHNEGS_DEFAULT:=STNEGATE; // NEGATE OR MINUS OUT
 LOCAL LimRec:=128;//LIMIT RECURSION
 //END CUSTOM
 LOCAL STPOS;
 LOCAL CHNEGS:=CHNEGS_DEFAULT;
 LOCAL CHPLUS:=CHPLUS_DEFAULT;//CURRENT USAGE
 LOCAL ZNaN;
 NOTIMP()
  MSGBOX("FTN: FMT NOT IMPLEMENTED");
 PAD(Ncopies,CH)
 //GENERATE NN COPIES OF CH (CH NORMALLY 1CH)
  LOCAL NN:=MIN(LimRec,Ncopies);//AVOID EXCESS RECURSION
  //LOCAL ST:="";
  //LOCAL COUNT:=NN;
  RETURN IFTE(NN>0,CH+PAD(NN-1,CH),"");
 RAISE_NAN()
  ZNaN:=ZNaN+1;
  IF FTN_SIGNALLING_NAN THEN
   MSGBOX("NaN:"+ZNaN);
 PLAYFMT(RL,ST)
 //JUST TRY SYNTAX
 //RL:REAL
 //ST:En or Fn or Sn
  //LOCAL RL:=#2;
  MSGBOX(CAS(format(RL,ST)));
  RETURN 1;
 //SUPPLEMENTARY HANDLING
 FTN_FMT_S()
 //FTN: RESET SHOWPLUSSIGN (TO OUR CHOSEN DEFAULT DEFINED HERE)
 //(APPLIES:MANTISSA; EE N/A)
 FTN_FMT_SP()
 //FTN: SET SHOWPLUSSIGN
  CHPLUS:="+";
 FTN_FMT_SS()
 //FTN:SUPPRESS SHOWPLUSSIGN
  CHPLUS:=" ";
 FTN_FMT_IN_BLANK(ST)
 //HANDLE BLANK CHARS ON INPUT
 //HANDLE FMT BLANKS:B BN BZ
  IF INSTRING(ST,"BZ") THEN
    NOTIMP();
 FTN_FMT_OUT_NUMSIGN(ST)
 //HANDLE FMT SIGNS: S SP SS
 //Z:NULL ST=RESET
 //INSTRING DETECTION EG "I SP" OK
  FTN_FMT_S();//SIGN: OUR SYSTEM DEFAULT
  CASE
   IF INSTRING(ST,"SP") THEN
    FTN_FMT_SP();
   IF INSTRING(ST,"SS") THEN
    FTN_FMT_SS();
   DEFAULT
 EXPORT FTN_FMT_II (FWIDTH,STR)
 //FTN: INPUT ST: INTEGER
 //GET INTEGER FROM STR OF FWIDTH DIGITS
 //FWIDTH:1..N INCLUDES SIGN
 //FWIDTH 0:F90: PARSE INTEGER IN STR
 //(SHOULD PARSE DIGITS. FOR NOW JUST EXPR ENTIRE STR)
 //STR:INCLUDES INTEGER,SPACE=0,*=OVERFLOW IN STR FORMAT
  LOCAL ST;
  LOCAL INUM:=0;
  LOCAL FW:=IP(FWIDTH);
  FTN_FMT_IN_BLANK("");//WHERE TO GET INPUT FORMAT FROM?
  //IGNORE WSP
  ST:=REPLACE(STR,SP,"");
  ST:=REPLACE(ST,STMINUS,STNEGATE);
  IF SIZE(ST) THEN
   IF FW THEN
    ST:=MID(ST,FW);
   IF INSTRING(ST,"*")  THEN
    //NAN- 0
    RAISE_NAN;
   ELSE //ASSUME DECIMAL NUM
    INUM:=EXPR(ST);
  ELSE //WSP==0
  RETURN IP(INUM);
 EXPORT FTN_FMT_A(FWIDTH,STR)
 //FTN:IO AN ST: ALPHA STRNG WIDTH FW
 //FTN:0: NO PADDING OR TRUNC
  LOCAL ST:=IFTE(FW,MID(STR,1,FW),STR);//TRUNC
  IF FW THEN
   IF FW-DIM(STR)>0 THEN
    //PAD TBD FW-LEN SP AT LEFT
    ST:=ST;
  RETURN ST;
 EXPORT FTN_FMT_I(FMTLST,INUM)
 //FTN:OUTPUT ST: INTEGER
 //FMTLST:"MAX.MIN" WIDTHS AS LIST
 //F90: MAX 0=NO PADDING
 //INUM:INTEGER
  LOCAL SCHAR;
  LOCAL ST:="";
  LOCAL FMT_ST;//PARAM TBD
  LOCAL FW:=0; //MAXWIDTH
  LOCAL FM:=0; //MINWIDTH
  //LOCAL FM:=5;//TEST
  LOCAL NUM:=IP(INUM);  //INGUARD
  LOCAL POSNUM:=ABS(NUM);
  LOCAL MODE_STD:=1; //STANDARD NUM FMT
  IF SIZE(FMTLST) THEN
   FMT_ST:=FMTLST(1);
   FW:=IP(FMTLST(2));//MAXWIDTH
   IF SIZE(FMTLST)>2 THEN
    FM:=FMTLST(3);
   ELSE //EMPTY LIST:DEFAULTS?
  FTN_FMT_OUT_NUMSIGN(FMT_ST);
  ST:=STRING(POSNUM,MODE_STD); //POSNUM
  IF FM THEN //MIN FIELD WIDTH
   ST:=PAD(FM-DIM(ST),"0")+ST; //INSERT LEADING ZEROS AS REQD
   //POSNUM WITH ANY LEADING ZEROS
  IF (NUM≥0) AND (DIM(ST)==FW) THEN
   SCHAR:=""; //SUPPRESS "+ " WHEN NEEDED TO FIT
  ELSE
   SCHAR:=IFTE(NUM≥0,CHPLUS,CHNEGS); //SELECT CURRENT SIGN
  ST:=SCHAR+ST;//SIGNED NUM WITH LEADING ZEROS
  IF AVOID_IE AND INSTRING(ST,"ᴇ") THEN
    //Bug: THE INSTRING HANDLES SYSTEMS LIKE HP
    //WHICH DELIVER INTEGERS WITH EXPONENTS
    //FORMATTED LIKE 1ᴇ12 IT MIGHT FIT
    //NB THE POINT AT WHICH HP STRING(N) RETURNS 1ᴇ12
    //IS GOVERNED BY N, IRRESPECTIVE OF FW
    ST:=PAD(MAX(FW,1),"*"); //OVERFLOW:STR TOO LARGE FOR HP INTEGER
    //IF FW 0 EMIT ONE *
  IF FW THEN //MAX FIELD WIDTH CHECKS
   CASE
    IF DIM(ST)>FW THEN
     ST:=PAD(FW,"*"); //OVERFLOW
    IF DIM(ST)<FW THEN
     ST:=PAD(FW-DIM(ST)," ")+ST; //PAD LEFT WITH SP
    DEFAULT
    //FITTED JUST RIGHT
  RETURN ST;
 EXPORT FTN_FMT_F()
 //FTN:OUTPUT ST: REAL FLOATING
 EXPORT FTN_FMT_E()
 //FTN:OUTPUT REAL EXPONENTIAL
 EXPORT FTN_FMT_G()
 //FTN:OUTPUT GENERAL REAL (E/F PER SIZE)
 //END FTN FMT API
 FTN_IO_RESET()
 //OUR COMMAND: RESET FTN DEFAULTS
 EXPORT FTNIO()
  STPOS:=1;
  FTN_IO_RESET();
  PLAYFMT(STPOS,"S0");
