01-16-2017, 05:04 PM
01-16-2017, 05:07 PM
Version 0.001
// List routines V0.001 StephenG1CMZ 2017
LOCAL TM;
LST_HasDups (LST,AnBOOL)
// RETURNS EITHER
// BOOL:"0 OR 1" IF element duplicated in LST
// OR POSITION OF 1st duplicate (slower)
LOCAL PS;
LOCAL II:=1;
IF SIZE(LST)≤1 THEN
RETURN 0;//SMALL LST==NO DUPS
ELSE
WHILE POS(LST,LST(II))==II AND II<SIZE(LST) DO
II:=II+1;
IF AnBOOL THEN
//RETURN BOOL
IF II<SIZE(LST) THEN
RETURN 1;//QUICKER THAN POS
ELSE
RETURN (POS(LST,LST(II))<II); //BOOL
ELSE
//RETURN POSITION
RETURN II;
ELSE
PS:=POS(LST,LST(II));
RETURN IFTE(PS==SIZE(LST),0,PS);
EXPORT IZ_HasDups(LST)
//RETURN 1 if LST Has Duplicates ELSE 0
RETURN LST_HasDups(LST,1);
EXPORT ZMISSINGPROC()
//WHY IS THIS MISSING FROM RUN LIST?
EXPORT Z_LST_Once(LST)
//Return LST with duplicates occuring once. Input unchanged.
LOCAL II;
LOCAL OUTLST:={};
//THIS SOLN-WORKS WHEREVER POS RECOGNISES ELEMENT WITHIN LST
FOR II FROM 1 TO SIZE(LST) DO
IF POS(OUTLST,LST(II))==0 THEN //NOT YET LISTED
OUTLST(0):=LST(II);
RETURN OUTLST;
//EACH ITEM NOW OCCURS ONCE ONLY
EXPORT Z_LST_OnceCS(LST)
//As LST_Once: Using CAS.
LOCAL SL:=STRING(LST);
LOCAL st;
st:=SL+" union "+SL;
mat2list(CAS(st));
EXPORT Z_POS_HasDups(LST)
//RETURN position of 1st Duplicate ELSE 0
//If you do not need position: IZ_HasDups returns 01
RETURN LST_HasDups(LST,0);
EXPORT Z_LST()
LOCAL NN;
LOCAL UNIQUELST:={};
LOCAL LST:=IP(RANDOM(1000,1,1ᴇ8));
UNIQUELST:=Z_LST_Once({1,2,2,2,2,3});
UNIQUELST:=Z_LST_OnceCS({1,2,2,2,2,3});
PRINT("WORKING");
TM:=TICKS;
NN:=LST_HasDups(LST,1);
MSGBOX(NN+" in "+(TICKS-TM));
//RETURN UNIQUELST;
11-01-2017, 02:10 AM
For whatever reason, the missing procedure now shows up in the run list, both on the current compiler and 8151.
I have created a new more comprehensive list API, without using this file in case it contained a rogue character...this thread is now deprecated and may be deleted in due course.
http://www.hpmuseum.org/forum/thread-9411.html
