Version. 0.1 meets the following objectives:
It demonstrates use of my CSV program
It allows airport data to be inspected (actually, it makes no assumptions and will display anything CSV can read if it fits onscreen).
It provides a readable list of locations, that might later be integrated with my GEODESY routines, later allowing distances to be calculated without having to enter latitude and longitude.
LOCAL GD_ID:="GEODATA V 0.1 © 2017 StephenG1CMZ";
LOCAL ST;
LOCAL LF:=CHAR(10);
LOCAL COMMA:=",";
LOCAL CR:=CHAR(13);
//LOCAL YL:=19;
LOCAL SHO_PROGRESS:=1;//TEST VALUE:IT IS A PARAMETER AND NOT CUSTOMISED
EXPORT AIRPORTS_DATA:={};
LOCAL FIELDS:={};
//IMPORT(CSV);
GD_IDS()
TEXTOUT_P(GD_ID,0,20);
EXPORT ABOUT()
RECT_P();
GD_IDS();
TEXTOUT_P("Data is not included, supply your own files",0,40);
TEXTOUT_P("Loading AIRPORTS data...Esc to continue",0,60);
WAIT;
EXPORT LOAD_AIRPORTS()
LOCAL XXNUM;
LOCAL FLIST2:="AIR"+{"0","1","2","3","4","5","6","7","8","9"};
//LOCAL FLIST2:="AIR"+{"0"};//TEST
//LOCAL FLIST1:={"G7"};
LOCAL TM;
PRINT();
RECT();//CLEAR SCREEN
GD_IDS();
XXNUM:=1;
CSV_SCR_PUT();//SAVE USER SCREEN
//RECT_P() HERE IF WE WISH TO DISCARD USER SCREEN
TM:=TICKS;
AIRPORTS_DATA:=CSV_Load(FLIST2,−1,XXNUM,1,SHO_PROGRESS);
CSV_SCR_GET();//RESTORE USER SREEN IF DESIRED
TEXTOUT_P("Elapsed "+((TICKS-TM)/1000)+" s",0,200,2);//FOR ACCURATE TIMING TAKE TICKS BEFORE SCR_GET
//MSGBOX("LOADED: "+SIZE(AIRPORTS_DATA));
L1:=AIRPORTS_DATA;
WAIT;
EXPORT FIND_AIRPORTS(Str)
LOCAL II,JJ,CHS,OKC;
LOCAL FT:=Str;
LOCAL MYLIST:={};
LOCAL MYLISTA:={};
//MSGBOX("DATA: "+SIZE(AIRPORTS_DATA));
FOR II FROM 1 TO SIZE(AIRPORTS_DATA) DO
//DEBUG;
FIELDS:=AIRPORTS_DATA(II);
IF TYPE(FIELDS)≠6 THEN
//PRINT("DOM: "+{TYPE(FIELDS),II});
IF TYPE(FIELDS)==DOM_LIST-1 THEN
IF SIZE(FIELDS) AND 1 THEN //NOT EMPTY
FOR JJ FROM 1 TO SIZE(FIELDS) DO
IF INSTRING(FIELDS(JJ),FT) THEN
MYLIST(0):=II;
//IF MORE THAN ONE FIELD MATCHES
//AIRPORT IS LISTED TWICE
DRAWMENU({II,JJ,SIZE(MYLIST)});//MATCHES
//DRAWMENU(II);//WAIT(0.1);
IF SIZE(MYLIST) THEN
FOR II FROM 1 TO SIZE(MYLIST) DO
FIELDS:=AIRPORTS_DATA(MYLIST(II));
MYLISTA(II):=FIELDS;
REPEAT
OKC:=CHOOSE(CHS,(SIZE(MYLIST))+" matches",MYLISTA);
// MSGBOX(MYLISTA(CHS));
FIELDS:=MYLISTA(CHS);
IF 1 THEN
RECT_P(0,0,320,200);
FOR II FROM 1 TO SIZE(FIELDS) DO
TEXTOUT_P((II)+": "+FIELDS(II),0,13*(II));
WAIT;
UNTIL OKC==0;
ELSE
MSGBOX("NO MATCH...TRY ANOTHER STRING")
PRINT("Done");
EXPORT GEODATA()
LOCAL OKC,TM,Str;
RECT_P();
ABOUT();
TEXTOUT_P("Loading",0,0);
LOAD_AIRPORTS();
WHILE OKC:=INPUT({{Str,[2]}},"Enter String (Any Data Field)","Find","Ensure strings are in quotes") DO
//TEXTOUT_P("Finding..."+Str,0,0);
TM:=TICKS;
FIND_AIRPORTS(Str);
TM:=TICKS-TM;
PRINT("Elapsed: "+(TM/1000)+" s");
WAIT;
The code has been tested using Airports data formatted as described in this thread, which explains how I had to split the file for the Android.
Link:
http://www.hpmuseum.org/forum/thread-7103.html
Note that the dataset is not in CSV format, in that some airport locations include commas within the location strings. The data remains readable, but additional fields are created.
I intend to improve CSV parsing.
Why airports? Apart from previously working on avionics software - There are less than 10 000 listed...(the professional dataset includes more).
So a single list can be searched. And the data is more localised than just listing capital cities.
The initial version makes no assumptions about the data fields.
Update: The input help says strings must be in quotes. Actually, you just need to enter Alpha lock and remove the default 0 (unless searching for a number).
