01-14-2017, 01:13 PM
Hello the following code has a syntax error
testCompiler file
instructions outside of the definitions testCASCompiler() & testCASCompiler2() are
and the compiler tells me that there are no errors, but the functions testCASCompiler() & testCASCompiler2() does run (contradiction)
For future firmware versions: when compiling any statement between CAS functions definitions, should not be allowed. (Comments should only be allowed)
ERROR
ok
Now if you uncomment the line ( -> abc ) If an error is detected, but still runs testCASCompiler() & testCASCompiler2(), because it was previously stored in memory. In this case the compiled version testCASCompiler() & testCASCompiler2() must be deleted from memory If an error is found in the reedition
testCompiler file
PHP Code:
#cas
testCASCompiler():=
begin
local expr1;
expr1:=trig2exp(sin(x)); //
return expr1;
end;
// -> abc
return /
testCASCompiler2():=
begin
local expr1;
expr1:=exp2trig(e^(2*x)); //
return expr1;
end;
#end
// -> abc
return /
ERROR
PHP Code:
#cas
fnt1():=
begin
local expr1;
return expr1;
end;
-> abc
return /
fnt2():=
begin
local expr2;
return expr2;
end;
#end
-> efg
ok
PHP Code:
#cas
fnt1():=
begin
local expr1;
return expr1;
end;
// -> abc
//return /
fnt2():=
begin
local expr2;
return expr2;
end;
#end
//-> efg
