01-11-2017, 07:32 PM
HI,
I would like submit you this little code for testing validity of a any date even for négatives years. It run good BUT the last CASE is an issue (and I dont' see why).
May be hights programmers like Dieter and many others, but Dieter is also expert in calendars, can help me to understand ? And surely optimized my code.
Thanks.
Thanks.
EXPORT TSTDate(J,M,A)
LOCAL ND, TST, JULBISS:=0,GREGBISS:=0;
CASE
IF J*M*A==0 THEN RETURN "Date ?"; END;
IF J<1 OR J>31 OR FP(J)≠0 THEN RETURN "date JJ?";END;
IF M<1 OR M>12 OR FP(M)≠0 THEN RETURN "Date MM?"; END;
IF A<−4712 OR A>9999 OR FP(A) ≠ 0 OR A=0 THEN RETURN "Date AAAA?";END;
IF M==04 OR M==06 OR M==09 OR M==11 AND J>30 THEN RETURN"Date JJ/MM?";END;
TST:=A+M/100+J/10000;
IF (A==1582 AND (TST>1582.1004
AND TST<1582.1015)) THEN
RETURN"GREG?";
CASE
IF (A>1582) AND (NOT(A MOD 4) AND A MOD 100)
OR (NOT(A MOD 400)) THEN GREGBISS:=1 END;
IF (A<1582) AND irem(A,4)==0 THEN
JULBISS:=1;END;
CASE
IF (M==2 AND JULBISS==1) OR (M==2 AND GREGBISS==1) AND J>29 THEN RETURN "Date>29/02?";
IF (M==2 AND JULBISS==0) OR (M==2 AND GREGBISS==0) AND J>28 THEN RETURN "Date>28/02?";
