(01-08-2017 10:34 PM)Eddie W. Shore Wrote: [ -> ]The Calculator Minimalist Programming Club
As I wrote earlier, the best and really useful calculator from CASIO is the
CASIO fx-50F - and it have
only 29 steps.
Some little marvel on it:
Equation solver: 14 steps, with secant method
Inverse Normal Distribution: same as above, uses the FMLA library of the calculator
Clausius-Clapeyron ODE solver: 16 steps, with Euler method
Clausius-Clapeyron ODE solver: 27 steps, with modified Euler (Predictor-Corrector method)
Flying height of a bullet, ODE solver: 23 steps, with Euler method
Approximation of irrational numbers with ratio of relative primes: 28 steps, short routine with a little trick (my favourite)
Finding Darcy friction factor (Colebrook-equation): ??? steps, iterative search
Rosin-Rammler distribution fit to measured particle size distribution: ??? steps, a short program in L.R. mode
And many little program during my work.
50F is the best well designed scientific calc and equipped with many useful additional things, like constants, six memory with arithmetics, alpha LCD (you can input/output data with labels A, B, C, D, E, F), two program area, linear regression and equation library. By the way few millimeters thick only, powered with solar cell and the layout and colour scheme well designed.
... maybe I like this calculator?!?
Csaba
