12-30-2016, 07:32 PM
Pseudocode interpreter/(Interprete de seudocódigo), for now only in English and Spanish interpreter, first release version Dec 2016 (Free version)
More info
ENG: https://play.google.com/store/apps/detai...code&hl=en
SPN: https://play.google.com/store/apps/detai...code&hl=es
Please test it and comment, Ideas, improvements, etc. are welcome
Thanks
PD:
A friend is the author. If you want to collaborate with the project please translate these two files to a particular language. (French, Portuguese, German, etc.)
KEYWORDS.TXT
errors.txt
Future release is to compete with the PC version (http://pseint.sourceforge.net/index.php?...cargas.php), which includes:
1: Step by Step Execution
2: Generate flowcharts
3: export pseudocode to n computer languages (c++/java/matlab, .... etc)
More info
Thanks
PD:
KEYWORDS.TXT
PHP Code:
// ENGLISH // SPANISH
BOOL : (TRUE | FALSE) ; // : (VERDADERO | FALSO) ;
ALGORITHM : A L G O R I T H M ; // : A L G O R I T M O;
ENDALGORITHM : E N D A L G O R I T H M ; // : F I N A L G O R I T M O;
PROCESS : P R O C E S S ; // : P R O C E S O;
ENDPROCESS : E N D P R O C E S S ; // : F I N P R O C E S O;
DEFINE : D E F I N E ; // : D E F I N I R;
AS : A S ; // : C O M O;
NUMBER : N U M B E R ; // : N U M E R O;
NUMERIC : N U M E R I C ; // : N U M E R I C O;
INTEGER : I N T E G E R ; // : E N T E R O;
CHARACTER : C H A R A C T E R ; // : C A R A C T E R;
REAL : R E A L ; // : R E A L;
BOOLEAN : B O O L E A N ; // : L O G I C O;
TEXT : T E X T ; // : T E X T O;
STRING : S T R I N G ; // : C A D E N A;
READ : R E A D ; // : L E E R;
WRITE : W R I T E ; // : E S C R I B I R;
DIMENSION : D I M E N S I O N ; // : D I M E N S I O N;
FOR : F O R ; // : P A R A;
TO : T O ; // : H A S T A;
WITH : W I T H ; // : C O N;
STEP : S T E P ; // : P A S O;
DO : D O ; // : H A C E R;
ENDFOR : E N D F O R ; // : F I N P A R A;
CLEAR : C L E A R ; // : B O R R A R;
SCREEN : S C R E E N ; // : P A N T A L L A;
WAIT : W A I T ; // : E S P E R A R;
KEY : K E Y ; // : T E C L A;
SECONDS : S E C O N D S ; // : S E G U N D O S;
SECOND : S E C O N D ; // : S E G U N D O;
MILLISECONDS : M I L L I S E C O N D S ; // : M I L I S E G U N D O S;
IF : I F ; // : S I;
THEN : T H E N ; // : E N T O N C E S;
ELSE : E L S E ; // : S I N O;
ENDIF : E N D I F ; // : F I N S I;
SWITCH : S W I T C H ; // : S E G U N;
CASE : C A S E ; // : C A S O;
OF : O F ; // : D E;
ANOTHER : A N O T H E R ; // : O T R O;
MODE : M O D E ; // : M O D O;
ENDSWITCH : E N D S W I T C H ; // : F I N S E G U N;
WHILE : W H I L E ; // : M I E N T R A S;
ENDWHILE : E N D W H I L E ; // : F I N M I E N T R A S;
REPEAT : R E P E A T ; // : R E P E T I R;
THAT : T H A T ; // : Q U E;
SUBPROCESS : S U B P R O C E S S ; // : S U B P R O C E S O;
ENDSUBPROCESS : E N D S U B P R O C E S S ; // : F I N S U B P R O C E S O;
FUNCTION : F U N C T I O N ; // : F U N C I O N;
ENDFUNCTION : E N D F U N C T I O N ; // : F I N F U N C I O N;
CLEAN : C L E A N ; // : L I M P I A R;
MODULE : M O D U L E ; // : M O D;
NO : N O ; // : N O;
TRUE : T R U E ; // : V E R D A D E R O;
FALSE : F A L S E ; // : F A L S O;
SQUAREROOT : S Q U A R E R O O T ; // : R C;
RANDOM : R A N D O M ; // : A Z A R;
errors.txt
PHP Code:
public static final String BOOLEAN_TRUE = "true"; // "verdadero"
public static final BOOLEAN_FALSE = "false"; // "falso"
public static final ERROR_INTEGER = "integer"; // "entero"
public static final ERROR_REAL = "real"; // "real"
public static final ERROR_LOGIC = "logical"; // "logico"
public static final ERROR_STRING = "string"; // "cadena"
public static final ERROR_INVALID_DATA_TYPE = "type not found"; // "tipo no encontrado"
public static final ERROR_INCOMPATIBLE_DATA_TYPE = "incompatible data type. Was expected: "; // "tipos de datos incompatibles. Se esperaba: "
public static final ERROR_WAS_FOUND =";was found: "; // ";se encontró: "
public static final ERROR_INVALID_BOOLEAN = "Incorrect Value for Boolean Variable"; // "Valor incorrecto para la variable booleana"
public static final ERROR_INVALID_TYPE = "invalid data type"; // "tipo de dato inválido"
public static final ERROR_SYMBOL_NAME_1 = "the symbol with name \""; // "el simbolo con nombre \""
public static final ERROR_SYMBOL_NAME_2 = "\" has already been declared "; // "\" ya ha sido declarado"
public static final ERROR_INTEGER_OR_REAL = "integer or real"; // "entero o real"
public static final ERROR_ARITHMETIC_NEGATION = "error in arithmetic negation"; // "error en negación aritmética"
public static final ERROR_BOOLEAN_NEGATION = "error in Boolean negation"; // "error en negación booleana"
public static final ERROR_RETURN_VAR_CREATED = "return variable was not created"; // "la variable de retorno no fue creada"
public static final ERROR_RETURN_VAR_INITIALIZED = "return variable not initialized"; // "variable de retorno no fue inicializada"
public static final ERROR_EXECUTION_CANCELED = "Execution canceled"; // "Ejecución cancelada"
public static final ERROR_INVALID_PARAMETERS = "Input parameters are missing"; // "Faltan parámetros de entrada"
public static final ERROR_INVALID_VARIABLE = "Unidentified variable"; // "Variable no identificada"
public static final ERROR_ARRAY_VARIABLE_1 = "the variable \""; // "la variable \""
public static final ERROR_ARRAY_VARIABLE_2 = "\" already initialized as not array"; // "\" ya se inicializo como no arreglo"
public static final ERROR_ARRAY_VARIABLE_3 = "can not declare that value in the array"; // "no se puede declarar ese valor en el arreglo"
public static final ERROR_DIVISION_BY_ZERO = "division between 0"; // "division entre 0"
public static final ERROR_INVALID_OPERATOR = "unknown operator"; // "operador desconocido"
public static final ERROR_SEMANTIC = "Semantic error"; // "Error semántico"
public static final ERROR_RUNTIME = "Runtime Error"; // "Error en tiempo de ejecución"
public static final ERROR_FUNCTION_WITH_NAME_0 = "the function \""; // "la función \""
public static final ERROR_FUNCTION_WITH_NAME_1 = "the function with name\""; // "la función con nombre \""
public static final ERROR_FUNCTION_WITH_NAME_2 = "\" has not been declared"; // "\" no ha sido declarada"
public static final ERROR_FUNCTION_WITH_NAME_3 = "\" returns a value that must go in an expression"; // "\" retorna un valor que debe ir en una expresión"
public static final ERROR_FUNCTION_WITH_NAME_4 = "\" is used in an expression but returns no value"; // "\" es usada en una expresión pero no retorna ningún valor"
public static final ERROR_FUNCTION_WITH_NAME_5 = "número incorrecto de parametros al llamar la función \""; // "número incorrecto de parametros al llamar la función \""
public static final ERROR_VARIABLE_WITH_NAME_1 = "the variable named \""; // "la variable con nombre \""
public static final ERROR_VARIABLE_WITH_NAME_2 = "\" has not been initialized"; // "\" no ha sido inicializada"
public static final ERROR_INVALID_INDEX_1 = "The index \""; // "El índice \""
public static final ERROR_INVALID_INDEX_2 = "\" in the array \""; // "\" en el arreglo \""
public static final ERROR_INVALID_INDEX_3 = "\" it's not valid"; // "\" no es válido"
public static final ERROR_INVALID_INDEX_4 = "an invalid position of the array was accessed:"; // "se accedió a una posición no valida del arreglo: "
public static final ERROR_INVALID_SYMBOL_1 = "the symbol with name \""; // "el símbolo con nombre \""
public static final ERROR_INVALID_SYMBOL_2 = "has already been declared \""; // "ya ha sido declarado \""
public static final ERROR_INVALID_DATA = "Incorrect data"; // "Datos incorrectos"
