12-23-2016, 07:26 PM
Differential Equations and Half-Increment Solution, Numerical Methods
The program HALFDIFF solves the numerical differential equation
d^2y/dt^2 = f(dy/dt, y, t) given the initial conditions y(t0) = y0 and dy/dt (t0) = dy0
In this notation, y is the independent variable and t is the dependent variable.
The Method
Let C = f(dy/dt, y, t). Give the change of t as Δt.
First Step:
With t = t0:
h_1/2 = dy0 + C * Δt/2
y1 = y0 + dy0 * Δt
Loop:
t = t0 + Δt
h_I+1/2 = h_I-1/2 + C * Δt
y_I+1 = y_I +h_I+1/2 * Δt
Repeat as many steps as desired.
For more details, click here: http://edspi31415.blogspot.com/2016/11/t...ntial.html
Source: Eiseberg, Robert M. Applied Mathematical Physics with Programmable Pocket Calculators McGraw-Hill, Inc: New York. 1976. ISBN 0-07-019109-3
Program HALFDIFF
250+ bytes, 12/22/2016
Edit f(A,Y,T) at line 5 where
A = y’(t), Y = y(t), T = t
Example: y’’(t) = y’(t) + 2 * t with y’(0) = 0, y(0) = 1, Delta t = 1, Max t = 6
FNF(A,Y,T) = A + 2 * T
Results:
T Y
1 2
2 8
3 26
4 70
5 168
6 376
The Method
First Step:
With t = t0:
y1 = y0 + dy0 * Δt
Loop:
t = t0 + Δt
Program HALFDIFF
5 DEF FNF(A,Y,T) = insert function y’(t), y(t), and t here
10 DESTROY A,Y,D,N,H,T
12 RADIANS
20 INPUT “dY/dX (0) = “, “0”; A
22 INPUT “Y(0) = “, “0”; Y
24 INPUT “DELTA T = “,”1”; D
26 INPUT “TMAX = “,”5”; N
28 T = D
44 H = A + FNF(A,Y,T) * D/2
48 Y = Y + H * D
50 DISP D; “, “; Y @ PAUSE
70 FOR I = 2 * D TO N STEP D
72 T = I @ A = H
76 H = H + FNF(A,Y,T) * D
78 Y = Y + H * D
80 DISP I; “, “; Y @ PAUSE
82 NEXT I
Results:
T Y
1 2
2 8
3 26
4 70
5 168
6 376
