12-13-2016, 08:27 PM
New versions should be appearing on the FTP sometime shortly. The "check for update" functionatlity in any current connectivity kit or emulator will prompt you when it finds the update. If you happened to be in the "public beta", it will prompt you for a download to the release version as well. If your network blocks direct connection, the direct link can be found at "ftp.hp.com/pub/calculators/Prime/".
The connectivity kit and emulator are now supported on both windows and mac. The iOS/Android/Winstore versions will be downloaded through your normal phone update mechanism as they are approved by the various stores.
HP Prime Connectivity Kit Installer - Windows
HP Prime Virtual Calculator Installer - Windows
HP Prime Connectivity Kit DMG - macOS
HP Prime Virtual Calculator DMG - macOS
This release is focused around getting macOS support, and all the store applications synchronized. There were some changes in the Core calculator code, but mostly this will be identical to the last release.
Note - There is no hardware calculator firmware release this round. This is expected.
Quote:Date Released: 2016/12/08
Internal Versions
HP Prime: 2016 12 08 (1.3.1.11226)
Connectivity Kit: 2016 12 08 (1.3.1.11226)
Description
Note that you will most likely lose data during the HP Prime app installation on iOS/Android/Winstore devices. Unfortunately, the data on those earlier app versions was not compatible with other OS and application versions. All files created and produced on any version of HP Prime are now compatible to support sharing with any device.
This document is not a complete list of all changes, but highlights specific items.
New Functionality (Virtual Calculator)
1. Working directory is now stored in <Documents>/HP Prime. On windows, old files located in %APPDATA%/HP_Prime will be moved over on first run.
2. International keyboards now fully supported.
a. Shortcuts like CTRL-C, CTRL-V won't leave the virtual calculator in "Shift" lock mode anymore.
3. "Connect To" menu has been removed. Any connected device will now receive communication instead of requiring unique selection first.
4. Updates now handled through HTTP only. Should be more reliable for those with network restrictions.
a. Documentation files for non-english will be downloaded on demand. This reduces overall file size on installation.
5. Able to communicate across an IP network to other systems on the same subnet.
6. App versions (iOS,Android,Winstore) - Synchronized with the "Prime Core". Updates and versions should no longer be out of sync moving forward.
New Functionality (Connectivity Kit)
1. Able to communicate across an IP network to other HP Prime apps on the same subnet.
a. To connect apps, either tap the top right corner screen of your simulated Prime and tap the "wireless" icon, or go to page 4 of your HOME SETTINGS. Pick the detected network name.
2. Updates now handled through HTTP only. Should be more reliable for those with network restrictions.
New Functionality (Prime Core)
1. A simulated off now runs when you do a shift-OFF in apps. (exclusively on shift-off and no other times)
Resolved issues and changes excluding CAS
1. Resolved display issue when using split-stem in Stem and Leaf stat plot and consecutive empty stems fell.
2. Resolved issue where really old calculator firmwares (>2.5yrs) didn't do anything in connkit. Now they will be put into "update" mode in the windows version.
Resolved issues and changes in CAS
3. Resolved issue with √(1_(MN/m^2)*1_(MPa)) in home generating an error but not 1e6_Pa (or kg/ms²)
4. Resolved issue with , and . setting when returning a fully qualified name from the toolbox.
5. Resolved issue with nested lists in EQ command - EQ({1,2,3},{1,2,{1,1}}
6. Resolved issue with RETURN command in IF THEN sequence in a user program.
7. Resolved issue with SORT and numbers 0<n<1.
8. Resolved issue with transparency and text when drawing.
