To update that 2015 firmware, you will need to run the con kit on a PC. Unfortunately, the update tool is not available on mac.
Cyrille
How did I end here...?
I have the latest CK and VC on windows 7 & 10 since these updates were live.
Both of them on these separate machines, I have to start them 3times to have it working.
VC will crash 2times before it ends up loading the right apps and programs.
CK crashes every time I try to do work on VC.
if I get both to stabilize I can't restore my backups....
if I connect my Prime calculate to CK it crashes....if I get to work by starting multiple times I can't backup nor restore.
(02-07-2017 12:57 AM)KeithB Wrote: [ -> ]I had a similar problem trying to update my old-rev new prime that I think had 8151 on it. I could not download an updater and get it to work. It would consistently crash on the PC and Mac.
I finally had to load the Connectivity kit from the CD that came with the calculator. Then everything worked, and I have the new firmware.
What is the update that could be installed on your calculator? Is it version 11226 or 10637?
I believe the latest version on real Primes (as opposed to the emulated Primes) is 10637.
Yes thanks, it seems like this is so, hopefully soon be ready for the Prime an update. I know that it is perhaps asking too much right now, but it would be nice if the HP Prime could then have an implementation in some language like LUA or another and be able to someday use a physics engine like Chipmunk, which allows to make games and programs very Powerful with physical magnitudes and simulations. See the following link
Physics Engine
New skin uses F1 for help and Apps button :/ cannot press Apps without using the mouse now
(03-13-2017 10:27 PM)eried Wrote: [ -> ]New skin uses F1 for help and Apps button :/ cannot press Apps without using the mouse now
About what topic are you talking about Eried?
(03-14-2017 03:21 AM)math7 Wrote: [ -> ] (03-13-2017 10:27 PM)eried Wrote: [ -> ]New skin uses F1 for help and Apps button :/ cannot press Apps without using the mouse now
Oh... It is the new version of the virtual prime skin included in this updated version. Old one allowed the user to press apps using the F1 key. The new one shares that key with the "help" so it presses the Apps key and opens the help pdf at the same time
