12-03-2016, 05:30 PM
The INPUT CMD is a DIALOG BOXES and is partially operating
if the variables are declared as local (coef1_a, coef2_b, coef3_c, coef4_d) do not work.
Commented the LOCAL VARIABLES
INPUTtest(); [enter] open the INPUT DialogBox, but then [enter] returns "Error: Bad argument type" Why?
Now without comment do not execute anything
INPUTtest(); [enter] INPUTtest() ?
PHP Code:
#cas
INPUTtest( ) :=
begin
//local coef1_a, coef2_b, coef3_c, coef4_d;
//coef1_a := 9; coef2_b := 8; coef3_c := 7; coef4_d := 6;
//local reset_coef1_a, reset_coef2_b, reset_coef3_c, reset_coef4_d;
//reset_coef1_a := 3; reset_coef2_b := 2; reset_coef3_c := 1; reset_coef4_d := 0;
local ObjectType_AllAllowed := -1;
local ObjectType_Real := 0;
local ObjectType_Integer := 1;
local ObjectType_String := 2;
local ObjectType_Complex := 3;
local ObjectType_Matrix := 4;
local ObjectType_List := 6;
local ObjectType_Function := 8;
local ObjectType_Unit := 9;
local ObjectType_CAS := 14;
local ok := 1;
local cancel := !ok;
local keyPress := 0;
local equ, equ1;
purge( a, b, c );
print; // Clear Terminal Window
print( "Use cursor keys ↑↓ to move the output screen" );
print( "Another key to continue after PAUSE" );
print( "" );
print( "[PAUSE]" ); wait();
print; // Clear Terminal Window again
print( "***** Deduction Quadratic Formula *****" ); // Title
print( "" );
print( "assume(a>0);" );
assume( a>0 );
equ:= (a*x^2+b*x+c) = 0;
print( string( equ ) );
print ( "[PAUSE]" ); wait( );
keyPress := msgbox( equ, true );
//print( "Key press for MSGBOX CMD: " + ifte( keyPress == ok, keyPress + "=[OK/ENTER]", keyPress + "=[ESC]" ) ); wait( );// 0 for [CANCEL], 1 for [OK/ENTER]
if keyPress == ok then
print( "Ans*4*a" );
equ := equ * 4*a; // ((a*x^2+b*x+c)*4*a) = 0
print( "" );
print( "expand(Ans)" );
equ := expand( equ ); // (4*a^2*x^2+4*a*b*x+4*a*c) = 0
print( "" );
print( "Ans+b^2" );
equ := equ + b^2; // (4*a^2*x^2 +4*a*b*x + 4*a*c+b^2 ) = (b^2)
print( "" );
print( "Ans-4*a*c" );
equ := equ - 4*a*c; // (4*a^2*x^2+4*a*b*x+4*a*c+b^2-4*a*c) = (b^2-4*a*c)
print( "" );
print( "simplify(Ans)" );
equ := simplify( equ ); // (4*a^2*x^2+4*a*b*x+b^2) = (-4*a*c+b^2)
print( "" );
print( "factor(Ans)" );
equ := factor( equ ); // (2*a*x+b)^2) = (-4*a*c+b^2)
print( "" );
print( "√(Ans)" );
assume( b>0 ); assume( c>0 );
equ := √( equ ); // (abs(2*a*x+b)) = (√(-4*a*c+b^2))
print( "" );
equ := expr( replace( string( equ ), "abs", "" ) ); // (2*a*x+b) = (√(-4*a*c+b^2))
print( "" );
print( "Ans-b" );
equ := equ - b; // (2*a*x+b-b) = (√(-4*a*c+b^2)-b)
print( "" );
equ := simplify( equ ); // (2*a*x-b) = (√(-4*a*c+b^2)-2*b)
print( "" );
print( "Ans/(2*a)" );
equ := equ / ( 2*a ); // (2*a*x/(2*a)) = (-b+√(-4*a*c+b^2))/(2*a)
print( "" );
equ := simplify( equ ); // x1 = (-b+√(-4*a*c+b^2))/(2*a)
equ := expr( replace( string( equ ), "x", "x1" ) );
print( "" );
print( "expr(replace(string(equ),"-b+","-b-"))" );
equ1 := expr( replace( string( equ ), "-b+", "-b-" ) ); // x2 = (-b-√[b^2-4*a*c])/(2*a)
equ1 := expr( replace( string( equ1 ), "x1", "x2" ) );
print( string( equ1 ) );
print( "[PAUSE]" ); wait( );
//keyPress := 1;
keyPress := input( { {coef1_a, [ObjectType_Real]}, {coef2_b, [ObjectType_Real]}, {coef3_c, [ObjectType_Real]}, {coef4_d, [ObjectType_Real] } }, "1a x² + b x + c = 0 ? ax²+bx=d", {"a:", "b:", "c:", "d:"}, {"Enter coeff a", "Enter coeff b", "Enter coeff c", "Enter coeff d"} , {reset_coef1_a,0,0,0}, {coef1_a,2,3,4} ) ;
a := 1;
b := 2;
c := 3;
//a := coef1_a;
//b := coef2_b;
//coef3_c := coef3_c-coef3_d; // => ax²+bx+c=0
//c := coef3_c;
return([ eval(equ), eval(equ1) ]);
end;
end;
return "done";
end;
#end
PHP Code:
#cas
INPUTtest():=
begin
coef1_a:=9; coef2_b:=8; coef3_c:=7; coef4_d:=6;
reset_coef1_a:=3; reset_coef2_b:=2; reset_coef3_c:=1; reset_coef4_d:=0;
input( { {coef1_a, [ObjectType_Real]}, {coef2_b, [ObjectType_Real]}, {coef3_c, [ObjectType_Real]}, {coef4_d, [ObjectType_Real] } }, "1a x² + b x + c = 0 ∨ ax²+bx=d", {"a:", "b:", "c:", "d:"}, {"Enter coeff a", "Enter coeff b", "Enter coeff c", "Enter coeff d"} , {reset_coef1_a,0,0,0}, {coef1_a,2,3,4} ) ;
return "done";
end;
#end
