Hello
The hp-prime forum can be more organized, I propose for example provides several subforums o "folders"
1: section "Bug reports or Problems" a system to follow, if they were corrected, if there really is no bug etc
2: Ideas & Wishes (Features wanted for next firmware , a system to see if they are approved, declined, in consideration etc
3: Questions & Answers, Tips & Tricks
4: a subforum for beginners & another for experts
5: a subforum to build a good document of the hp-prime
6: libraries and programs
Think if all our files are stored in a single folder, Or think if the help of the hp-prime (HELP KEY) was in a single "folder"
The topic of additional forums and sub-forums has come up many times. While this is really a question for our host, Dave, I'm pretty sure that he's happy with the current structure.
Why don't we simply cut off discussions about the Prime until it turns a Museum's item, when it will be dismissed?
It may be a good idea from a point of view, but I think that the subforums have been created having considerations like participation and concentrated information, affecting a little the organization of sub-themes within sub-themes, as for me, I am more comfortable to review the minor Number of possible forums.
[Google translate]
Dividing into forum, each user checks what he wants, instead of seeing all the discussions in a single item.
The Prime is OT in this forum, and the only reason to have a Prime section is to keep on-topic secions clear from postings about it.
Is it possible to filter the View Today's Posts listing to have Prime content not even showing up?
(01-04-2017 08:44 AM)Thomas Radtke Wrote: [ -> ]Is it possible to filter the View Today's Posts listing to have Prime content not even showing up?
I second this!
(01-04-2017 09:11 AM)Massimo Gnerucci Wrote: [ -> ] (01-04-2017 08:44 AM)Thomas Radtke Wrote: [ -> ]Is it possible to filter the View Today's Posts listing to have Prime content not even showing up?
I second this!
I recently discovered that I can sort the today's post table by forum, which means I can ignore all the Prime posts as a single block.
(01-04-2017 09:40 AM)EdS2 Wrote: [ -> ]I recently discovered that I can sort the today's post table by forum, which means I can ignore all the Prime posts as a single block.
Thanks! Much better, but maybe Prime subjects could appear in light grey or something? That would make it much easier for Prime-fans to identify their topics, as they should be used to barely visible texts by now
Here's a bookmarklet to disappear the HP Prime rows:
Quote:javascript:(function(){[].slice.call(document.querySelectorAll('a'), 0).forEach(function(e){if (('innerHTML' in e) && e.innerHTML=="HP Prime"){e.parentElement.parentElement.style.display='none'}})})();void(0)
(Make a new bookmark, of any page at all, then edit it and paste that line into the target address, and edit the bookmark name to noPrime or similar.)
