Full Version: Problem with Laplace transform [SOLVED]
The command laplace(SIN(t*pi/10)*(Heaviside(t)-Heaviside(t-10)),t,s) works correctly.
[attachment=4139]
Now if instead of the number 10 we use a constant (a), and execute the commands assume(a>0) and laplace(SIN(t*pi/a)*(Heaviside(t)-Heaviside(t-a)),t,s) , the result is not correct.
[attachment=4141]
It should be the same as in the first image, substituting a for 10 in the numerator, and a^2 for 100 in the denominator.
The program XCAS gives correct answers in both cases.
The version of giac in the current firmware is older than in Xcas, a bug has certainly be fixed.
Corrected in firmware 13333.
Thanks to the HP Prime Team!
