10-31-2016, 05:50 AM
I'm trying to make a drawing in the Prime, but I realize I can't rotate texts!
I just wanted to rotate the "distance=?" text a couple of degrees, so it aligns with the green line (screen shot).
Here's my code:
EXPORT AboutESP()
RECT();
DIMGROB_P(G1,320,240);
RECT_P(G1,RGB(255,255,255));
LINE_P(G1,0,197,320,50,RGB(0,0,0));
LINE_P(G1,52,153,265,55,RGB(40,220,170));
LINE_P(G1,57,165,44,137,RGB(0,0,0));
LINE_P(G1,270,68,260,41,RGB(0,0,0));
RECT_P(G1,0,0,320,26,RGB(0,160,128));
TEXTOUT_P("Finding the distance between 2 points.",G1,25,2,4,RGB(255,255,255));
TEXTOUT_P("(x1,y1)",G1,55,175,2,RGB(0,0,0));
TEXTOUT_P("(x2,y2)",G1,270,79,2,RGB(0,0,0));
TEXTOUT_P("●",G1,56,162,3,RGB(255,0,0));
TEXTOUT_P("●",G1,268,65,3,RGB(255,0,0));
TEXTOUT_P("distance=?",G1,100,85,5,RGB(255,0,0));//this one I need to rotate.
TRIANGLE_P(G1,255,57,257,61,266,54,RGB(0,0,0));
TRIANGLE_P(G1,62,151,51,154,60,146,RGB(0,0,0));
BLIT_P(G0,G1);
FREEZE;
I'll appreciate any help, Thank you.
Here's my code:
EXPORT AboutESP()
RECT();
BLIT_P(G0,G1);
FREEZE;
