10-27-2016, 06:18 PM
10-28-2016, 07:11 PM
(10-27-2016 06:18 PM)johnet123 Wrote: [ -> ]I noticed that the negative sign in front of a fraction is barely visible. Try 1/2 and then the +/- key to see what to see what I mean.
Are you using the large font? It is worsened by that font size
10-28-2016, 11:39 PM
Yes, I was using the large font. Reducing the font size appears to correct the problem. I guess if you have bad eyesight, as I do, it is a choice between seeing the numbers and characters or the unary minus sign.
