11-01-2016, 10:32 PM
(11-01-2016 10:00 PM)Gene Wrote: [ -> ]The rom could include a label that uses the PASN functions to assign the AOS global labels as an initialization routine. Don't have a 41CX? then don't use that label. :-) Or if nothing else, running it would simply produce an error.
I think this may be omitted.
(11-01-2016 10:00 PM)Gene Wrote: [ -> ]I had thought these assignments:
Labels +, -, * and / to the corresponding keys.
Label = to the ENTER key.
Label YX to the Y^X key.
Labels < and > to the X<>Y and RDN key. (these <> characters are shift I and J in alpha).
X<>Y and RDN are fine since these keys are not used in AOS mode.
(11-01-2016 10:00 PM)Gene Wrote: [ -> ]I thought shift backarrow for CLR and CHS itself for CHS. This would be user mode only so if you want to do the CHS real function switch out of user mode. Where else would you put the CHS assignment ?
Maybe Shift CHS.
But first we should be sure the CHS routine is working as it is supposed to.
(11-01-2016 10:00 PM)Gene Wrote: [ -> ]I might take a swing at the easier golf program. I think that's a good thing to consider?
Do you have the 41 version of Golf that you referenced ?
Sure, here it is. It's essentially a 1:1 translation of the original 67/97 version.
Dieter
