10-23-2016, 01:38 AM
Very often for work, but mostly because I'm used to always do so, I use the ratio calculation. I wrote a simple program that solves ratio calculation (a : b = c : d), and I want to share it with you here. The program automatically solve the equation for the term equal to zero.
I hope will be useful!!!
//Ratio Function By Simone Selleri.
//Version 1.0 - October 2016
//This function solve a ratio equation (a:b=c:d)
//for the value equal to 0.
//SYNTAX: ratio(a,b,c,d)
//Examples: ratio(10,20,30,0) gives 60
// ratio(10,20,0,60) gives 30
// ratio(10,0,30,60) gives 20
// ratio(0,20,30,60) gives 10
//any question mail to: simone.selleri@gmail.com
EXPORT ratio(a,b,c,d)
a▶A;b▶B;c▶C;d▶D;
"A/B=C/D"▶E2;
CASE
IF A==0 THEN SOLVE(E2,A);END;
IF B==0 THEN SOLVE(E2,B);END;
IF C==0 THEN SOLVE(E2,C);END;
IF D==0 THEN SOLVE(E2,D);END;
