10-19-2016, 11:49 AM
Official HP Support on their website is pretty dismal hoping you guys can help me.
Problem first arose when I was trying to use the odesolve command when I go to use the "[]" brackets it comes up with the brackets with a blank space for input and a plus/minus sign on the right hand side inside the bracket, when I try to delete the plus minus it wipes the whole input. It also wont display commas.
To insert the brackets I have tried both shift --> Chars and shift --> "5"
I am using the example: odesolve(sin(t*y),[t,y],[0,1],2) and it wont let me put in [t,y].
Am I doing something wrong or have I found a bug in the code?
HP Prime:
Software version: 2016 08 29 (10637)
Hardware Version A
CAS ver. 1.1.2-11
Operating System: V0.048.635
Caleb.
HP Prime:
Hardware Version A
CAS ver. 1.1.2-11
Caleb.
