I am making a program derived from Spreedsheet, that will store data in the Spreadsheet. I would like to have an option to clear the spreadsheet but I cant find the command to do that. Is there a command to clear/reset the cells of the spreadsheet?
Thanks
Doug
I found away to do it by using A1:B1000:="";
From the Apps main menu, select Spreadsheet using the cursor (so that App icons are still visible with the Spreadsheet selected) then tap on the Reset menu key; this will reset the Spreadsheet (or any selected App) back to default settings and erase all data in that App.
Thanks I actually just wanted to clear 2 columns, and found a good way to do it, the A1:B800:="" made for a big app a better way ended up being A1:B800:={{}} worked, I guess each column is a list
(02-18-2014 04:34 AM)Dougggg Wrote: [ -> ]I am making a program derived from Spreedsheet, that will store data in the Spreadsheet. I would like to have an option to clear the spreadsheet but I cant find the command to do that. Is there a command to clear/reset the cells of the spreadsheet?
Thanks
Doug
Dear All,
Inside a program you can use this syntax:
In ROM 5106:
Spreadsheet.Cell(0,0,-1):=Spreadsheet.AA1000;
(You can use it from command line too)
BUT in ROM 5447 it DOESN´T WORK,
then I asked to Cyrille and no response,... I have a large program with many methods that mix all results in the spreadsheet ... or the user need to ERASE IT BEFORE RUNNING THE PROG.
PLEASE CYRILLE What is the new SYNTAX ??
best regards!!
joseph
