10-12-2016, 06:20 PM
Don't be put off by the code - it includes three different implementations all exhibiting the same bug, so you only need to check one...Each one is just a dozen or so lines of trigonometry.
I have coded up three routines for converting a pair of LatLong points to a distance.
HAVERS implements a Haversine spherical Earth calculation
VINCENTYS implements a simplification of Vincenty's formula for a spherical Earth.
These two return practically identical results (trivial rounding in micrometres).
Z-VINCENTY is the normal ellipsoidal formula, perhaps a few km away from the other results.
All 3 exhibit the same bug: Reporting a distance of 1km for an expected distance of 54 km, for example. (The expected result here is from Geoscience Australia).
Since all three implementations are wrong, I assume their is some common error.
I have tried changing my atan2 algorithm and YY XX parameter sequence.
I have tried calculating the longitude difference as abs(LON2-LON1) whereas other sources just subtract. I am aware that VINCENTY has a few superfluous brackets compared to other online sources, but that would not cause all 3 to fail.
I have stared at the code long enough that I need a break before having another look...
Can anyone else see something I have misunderstood in all 3 implementations?
Or recommend a worked example with intermediate values that I can check my code against?
Or is it simply that this application demands more precision than the Prime has?
LOCAL SP:=" ";
LOCAL EPSILON_V:=3ᴇ−11;
LOCAL LoopSafe:=140;
LOCAL LOOPCOUNT,VALIDITY;
LOCAL WGS84RAm:=6378137.0;
LOCAL WGS84FLATTENINV:=298.257223563;
LOCAL WGS84FLATTEN:=1/WGS84FLATTENINV;
LOCAL RA:=WGS84RAm; //RADIUS EQ
//LOCAL RA:=6378388;//TEST
LOCAL FLATTEN:=WGS84FLATTEN;
LOCAL RB:=IFTE(RA,(1-FLATTEN)*RA,0);//RADIUS POLAR
LOCAL ESS:={RA,RB,FLATTEN};//DEFINE ELLIPSOID SIZE AND SHAPE
LOCAL ESS_UNITS:="m";
D2R(DEGS)
RETURN DEGS*(π/180);
R2D(RADS)
RETURN RADS*(180/π);
ATAN2_UNUSEDYX(YY,XX)
BEGIN //MY ATAN2
IF XX==0 AND YY==0 THEN
RETURN 0; //CONVENIENT;
//-π..π
RETURN ARG(XX+*YY);//BUILT-IN HANDLES MOST
ATAN2YX(YY,XX)
LOCAL RESULT;
IF XX>0 THEN RETURN ATAN(YY/XX); END;
IF YY>0 THEN
RETURN (π/2 - ATAN(XX/YY));
IF YY<0 THEN
RETURN (−π/2 - ATAN(XX/YY));
IF XX<0 THEN
RETURN (ATAN(YY/XX) + π); //PLUSMINUS TBD
IF YY==0 AND XX==0 THEN RETURN (0); END;
//NEVER REACH
PRINT("ATAN2 FAULTY");
HAV(THETA)
//HAVERSINE
LOCAL HS:=SIN(THETA/2);
RETURN HS^2;
REPORT_SHAPE()
LOCAL SP:=" ";
PRINT();
PRINT("RA: "+ESS(1)+SP+ESS_UNITS);
PRINT("RB: "+ESS(2)+SP+ESS_UNITS);
PRINT("f: "+ESS(3));
IF ESS(3)≠0 THEN
PRINT("1/f: "+1/ESS(3));
PRINT("Esc");
WAIT;
EXPORT Z_VINCENTY(LAT1,LON1,LAT2,LON2)
// GEODESY INVERSE PROBLEM ELLIPSOIDAL
// RETURNS DIST IN SAME UNITS AS R
// LAT AND LON IN DEGREES
LOCAL UU1,SINUU1,COSUU1; //U1 AUX LATITUDE
LOCAL UU2,SINUU2,COSUU2; //U2 AUX LATITUDE
LOCAL USQ;
LOCAL AAA,BBB;
LOCAL LONDIFFradians; //L=DIFF IN LON
LOCAL PHI1,PHI2;
LOCAL LAMBDA,SINLAMBDA,COSLAMBDA,LAMBDAOLD;
LOCAL SIGMA,SIN_SIGMA,COS_SIGMA,DELTA_SIGMA,SINSQ_SIGMA; //AUX ARC LENGTH
LOCAL SIN_ALPHA,COSSQ_ALPHA;
LOCAL COS_2SIGMAM,COSSQ_2SIGMAM;
LOCAL CC;
LOCAL BRACKET_TERM;
LOCAL DISTS;
LOCAL AZ_FWD,AZ_REV;
LOCAL RA:=ESS(1);
LOCAL RB:=ESS(2);
LOCAL FLATTEN:=ESS(3);
//REPORT_SHAPE;
// CALC L
LONDIFFradians:=D2R(LON2-LON1); //DIFF IN LON
// CALC U1 U2
PHI1:=D2R(LAT1);
PHI2:=D2R(LAT2);
UU1:=ATAN(1-FLATTEN)*TAN(PHI1);//TBC
UU2:=ATAN(1-FLATTEN)*TAN(PHI2);//TBC
//TO CALC LAMBDA:
// PRE-CALC U1 TRIG ONCEONLY
SINUU1:=SIN(UU1); COSUU1:=COS(UU1);
// PRE-CALC U2 TRIG EACH POSITION
SINUU2:=SIN(UU2); COSUU2:=COS(UU2);
//ITERATE CALCULATING LAMBDA
LOOPCOUNT:=0;
LAMBDA:=LONDIFFradians; //V13: DIFF IN LON ON AUX. FIRST APPROX
//PRINT(); PRINT(LAMBDA);
REPEAT
LOOPCOUNT:=LOOPCOUNT+1;
SINLAMBDA:=SIN(LAMBDA); COSLAMBDA:=COS(LAMBDA); //PRECALC
//V14
BRACKET_TERM:=(COSUU1*SINUU2 - SINUU1*COSUU2*COSLAMBDA);
SINSQ_SIGMA:=(COSUU2*SINLAMBDA)^2 + (BRACKET_TERM)^2;
IF SINSQ_SIGMA==0 THEN
//PRINT("SINσ 0: NO DISTANCE");
//0 DISTANCE MIGHT SUGGEST UNDERFLOW
RETURN {1,0,0,0};//VALID ZERO
SIN_SIGMA:=√(SINSQ_SIGMA);
//V15
COS_SIGMA:=SINUU1*SINUU2 + COSUU1*COSUU2*COSLAMBDA;
//V16
SIGMA:=ATAN2YX(SIN_SIGMA,COS_SIGMA);
//V17
SIN_ALPHA:=(COSUU1*COSUU2*SINLAMBDA)/SIN_SIGMA;
COSSQ_ALPHA:=1-(SIN_ALPHA*SIN_ALPHA);
//V18
IF COSSQ_ALPHA==0 THEN
//PRINT("AVOID COSSQα 0");
COS_2SIGMAM:=0;
ELSE
COS_2SIGMAM:=COS_SIGMA - (2*SINUU1*SINUU2/COSSQ_ALPHA);
CC:=(FLATTEN/16)*COSSQ_ALPHA*(4 + FLATTEN*(4 - 3*COSSQ_ALPHA));
LAMBDAOLD:=LAMBDA;
LAMBDA:=LONDIFFradians + (1-CC)*FLATTEN*SIN_ALPHA*(SIGMA + CC*SIN_SIGMA*(COS_2SIGMAM + CC*COS_SIGMA*(−1+2*(COS_2SIGMAM*COS_2SIGMAM))));
//PRINT(LAMBDA);
UNTIL (ABS(LAMBDA-LAMBDAOLD)≤EPSILON_V) OR (LOOPCOUNT≥LoopSafe);
//PRINT("LOOP DUN");
//V19
USQ:=COSSQ_ALPHA*((RA^2 - RB^2)/(RB^2));
//(V3)
AAA:=1 + (USQ/16384)*(4096 + USQ*(−768 + USQ*(320 - 175*USQ)));
//(V4)
BBB:= (USQ/ 1024)*( 256 + USQ*(−128 + USQ*( 74 - 47*USQ)));
//(V6)
COSSQ_2SIGMAM:=(COS_2SIGMAM)^2;
DELTA_SIGMA:=(1/6)*BBB*COS_2SIGMAM*(−3+4*(SIN_ALPHA)^2)*(−3+4*COSSQ_2SIGMAM) ;
DELTA_SIGMA:=(1/4)*BBB*(COS_SIGMA*(−1+2*COSSQ_2SIGMAM)) - DELTA_SIGMA ;
DELTA_SIGMA:=BBB*SIN_SIGMA*(COS_2SIGMAM + DELTA_SIGMA);
DISTS:=AAA*(SIGMA - DELTA_SIGMA);
//PRINT("ANGULAR FRACTIONAL DIST: "+DISTS/π);
DISTS:=RB*DISTS;
//V20:FORWARD AZIMUTH
AZ_FWD:=ATAN2YX((COSUU2*SINLAMBDA),BRACKET_TERM);
AZ_FWD:=IFTE(AZ_FWD<0,AZ_FWD+2*π,AZ_FWD);//BEARINGS ARE POSITIVE
//V21:REVERSE AZIMUTH
AZ_REV:=ATAN2YX((COSUU1*SINLAMBDA),(−SINUU1*COSUU2 + COSUU1*SINUU2*COSLAMBDA));
AZ_REV:=IFTE(AZ_REV<0,AZ_REV+2*π,AZ_REV);//BEARINGS ARE POSITIVE
DISTS:=ROUND(DISTS,0);//VINCENTY CLAIMS mm,
//RETURN DIST,AZIMUTH,REVERSE AZIMUTH,(LOOPCOUNT:DIAGNOSTIC)
RETURN {DISTS,R2D(AZ_FWD),R2D(AZ_REV),LOOPCOUNT};
VINCENTYS(RA,RB,LAT1,LON1,LAT2,LON2)
//SPHERICAL SIMPLIFICATION: WIKIPEDIA
//USE RR=(2RA+RB)/3
LOCAL NUM,DEN;
LOCAL PHI1,PHI2;
LOCAL SINPHI1,SINPHI2,COSPHI1,COSPHI2;
LOCAL COSDELTALAMBDA,DELTALAMBDA;//DELTALONG rad
LOCAL ANGDIST,DIST;
LOCAL RR:=(2*RA+RB)/3;
PHI1:=D2R(LAT1);
PHI2:=D2R(LAT2);
DELTALAMBDA:=D2R((LON2-LON1));//SHOULD WE ABS?
COSDELTALAMBDA:=COS(DELTALAMBDA);
SINPHI1:=SIN(PHI1); COSPHI1:=COS(PHI1);
SINPHI2:=SIN(PHI2); COSPHI2:=COS(PHI2);
NUM:=√(((COSPHI2*SIN(DELTALAMBDA))^2) + (COSPHI1*SINPHI2 - SINPHI1*COSPHI2*COSDELTALAMBDA)^2);
DEN:=(SINPHI1*SINPHI2 + COSPHI1*COSPHI2*COSDELTALAMBDA);
ANGDIST:=ATAN2YX(NUM,DEN);
//PRINT("ANGDIST "+ANGDIST);
DIST:=RR*ANGDIST;
//HAVERSINE AND VINCENTYSPHERICAL RETURN IDENTICAL RESULTS
//APART FROM VERY TRIVIAL ROUNDING
//SO SERVE TO CHECK EACH OTHER
//(TO BE SURE THAT IS ALWAYS SO:CHECK MIN1 GUARD CONDITIONS ETC MATCH)
HAVERS(LAT1,LON1,LAT2,LON2)
LOCAL RR:=(2*ESS(1)+ESS(2))/3;
LOCAL DLON:=D2R(LON2-LON1);
LOCAL DLAT:=D2R(LAT2-LAT1);
LOCAL AA:=HAV(DLAT) + (COS(D2R(LAT1))*COS(D2R(LAT2))*HAV(DLON));
LOCAL CC:=2*ASIN(MIN(1,√(AA)));//MIN 1 AVOIDS ROUNDING OUTRANGE
LOCAL DD:=RR*CC;
RETURN DD;
ATAN2TEST()
LOCAL AA,BB,RR,RRR;
WHILE 1 DO
AA:=RANDOM();
BB:=RANDOM();
RR:=ATAN2YX(AA,BB);
RRR:=ATAN2YX(AA,BB);
IF ABS(RR-RRR)>1ᴇ−11 THEN
PRINT({RR,RRR});
IF ABS(RR)>π THEN
PRINT(RR/π);
A_VINCENTY(LAT1,LON1,LAT2,LON2)
LOCAL TM,RESULT,DISTS;
PRINT(" ");
PRINT("From LAT "+HMS→(LAT1)+" "+→HMS(LAT1));
PRINT("From LON "+HMS→(LON1)+" "+→HMS(LON1));
PRINT("To LAT "+HMS→(LAT2)+" "+→HMS(LAT2));
PRINT("To LON "+HMS→(LON2)+" "+→HMS(LON2));
TM:=TICKS;
RESULT:=HAVERS(LAT1,LON1,LAT2,LON2);
PRINT("HAVERS: "+(RESULT/1000)+" km");
RESULT:=VINCENTYS(ESS(1),ESS(2),LAT1,LON1,LAT2,LON2);
PRINT("SPHERICAL: "+(RESULT/1000)+" km");
RESULT:=Z_VINCENTY(LAT1,LON1,LAT2,LON2);
TM:=TICKS-TM;
//PRINT("Elapsed "+(TM/1000)+" s");
PRINT("VALIDITY "+(LOOPCOUNT<LoopSafe)+" "+RESULT(4));//BOOLEAN, LOOPCOUNT (LOWER=>BETTER CONVERGENCE)
DISTS:=RESULT(1);
PRINT("DISTANCE: "+(DISTS/1000)+SP+" km");
//PRINT(" AZ: "+→HMS(RESULT(2)));
//PRINT(" AZ: "+→HMS(RESULT(3)));
EXPORT STEPPED()
LOCAL II;
FOR II FROM 1 TO 89 STEP 30 DO
A_VINCENTY(−II,0,II,0);
EXPORT VINCENTY()
//ATAN2TEST();
//PRINT("TESTED"); WAIT;
REPORT_SHAPE();
A_VINCENTY(50°03′58.76″,−005°42′53.10″,58°38′38.48″,−003°04′12.34″);//50PERCENT
PRINT("EXPECT 969 954_m");
A_VINCENTY(−37°57′3.72030″,144°25′29.52440″,−37°39′10.15610″,143°55′35.38390″);//EXPECTS 54972m
PRINT("EXPECTED: 54972m");//VINCENTY AUSTRALIA
A_VINCENTY(31.8300167,35.0662833,31.83000000,35.0708167);
PRINT("PYTHON: CIRCLE 428.4 VIN 429.1677 m");
//A_VINCENTY(0,0,0.5,179.5);
//A_VINCENTY(0,0,0.5,179.7);//WILL NOT CONVERGE
//A_VINCENTY(0,0,0,90);
//A_VINCENTY(0,0,0.5,0.5);
//A_VINCENTY(2,2,2,2);
STEPPED();
//PRINT("SEMI: "+π*ESS(1));//MAX
