09-28-2016, 05:02 PM
First of all, I playing around with the new 10637 version on my physical Prime.
Excellent update!! Thanks HP Prime team!!
I have a question about the double quotes.
As an example;
I want to make a list with text, using the list editor (Shift 7)
I select L1 and inputting AAA (just an example) and I'm forgotten to use the double quotes.
I want to edit the text to put a double quote before and a double quote after the text.
With the curser I go before the text and insert from "Chars" (Shift Vars) a single double quote, I get now two double quotes!! It is not possible to delete one of the double quotes. Deleting the second one nothing happens, deleting the first one both double quotes are deleted.
I must delete the whole text, inserting two double quotes (ALPHA 0) and I must type the whole text again between it. (Okay, AAA is not a difficult text!)
What I'm doing wrong? Or is this behavior changed in 10637?
Same with the single quotes and something (sometimes) with editing the underscore on the command line, but difficult for me to explain.
It works (with the double quotes) "correct" in Notes and in the Program Editor.
As an example;
