This is a little late to the party, but better late than never, I guess.
As is my usual practice, I did not look at the discussion of solutions to the HHC 2016 RPN Programming Contest until I decided that I was satisfied with my own efforts or reached a dead end. I did look at the thread before the embargo was lifted, and saw Pauli's post that he had a 32 step solution that ran instantaneously. Upon seeing that, I figured there must be some simple(?) technique to solve the challenge of which I was not aware. But since it is fun to attack Gene's challenges, I went ahead and pursued my first thought, which was of course, brute force: form the lowest k-digit number, find the sum of its digits, see if it equals the target sum, if so, increment a counter, if not, don't increment the counter, then increment the k-digit number and repeat up to the highest k-digit number. I suspected that it might take a long time to run on a 34s for some inputs, but I went ahead anyway, and was able to get a program up and running fairly quickly. It took about 75 seconds to return 35 as the answer to f(4,5), Gene's explanatory example. Based on that timing, figuring about a factor of 10 in execution time for each additional digit, I did not want to run it on even a 5 digit number. The next day, I entered the program into the wp34s emulator on my PC. It of course gave much quicker results, so I was able to check Gene's (valid) sample cases. Feeling brave, I turned the emulator loose on f(9,56) and let it run overnight. I was not at the PC when it finished, but my best guess is that it took 10 to 12 hours to return 9,286,233. In case anyone is interested, here is the code for that brute force program:
001 LBL"HHC"
002 STO 00 store target sum n in 00
003 x<> Y swap
004 10^x Form maximum k-digit number +1
005 ROUNDI make sure it is an integer
006 STO A store max k-digit+1 number in A
007 SDR 001 Form minimum k-digit number
008 STO B store in B
009 CLx clear x
010 STO C store zero in C, count of digit sums n in k-digit number
011 CLx clear x (target of BACK in step 030)
012 STO D store zero in D, sum of digits in current number
013 RCL B recall current number whose digits are being summed
014 SDR 001 divide by 10
015 ENTER enter
016 FP fractional part
017 STO- Y subtract fractional part from current number divided by 10
018 SDL 001 multiply fractional part by 10
019 STO+ D add to D, sum of digits of current number
020 Rdn roll down
021 x=/=0? is number being summed not equal 0?
022 BACK 008 if not, loop back to sum next digit
023 RCL D when done, recall sum of digits
024 x=/=? 00 sum of digits not equal to target sum?
025 SKIP 001 if not, skip
026 INC C if equal, increment count of digit sums equal to n
027 RCL A recall maximum k-digit number + 1
028 INC B increment current number whose digits to be summed
029 x=/=? B next number not equal maximum k-digit+1?
030 BACK 019 if not, go back to sum digits of next no. and check sum
031 RCL C if equal, recall count of digits sums equal to n
032 END done
At this point, my suspicions were of course confirmed that this was not the optimal approach to this problem, so I did not attempt to refine the program to reduce the number of steps, registers used, etc. To move forward, I decided to see if I could discern some sort of pattern. I started building a table which presented the counts of digit sums for number of digits vs. desired sum of the digits, like this:
sum of Number of Digits
Digits 1 2 3 4 5 6 7 8 9
1 1 1 1 1 1 1 1 1 1
2 1 2 3 4 5 6 7 8 9
3 1 3 6 10 15 21 28 36 45
4 ...
I was able to figure out the answers for the simple values by hand, used my above program on the emulator for up to 6-digit values, and eventually used Gene's calculation source which he kindly provided directly to me to extend the above table in excel. In an effort to make a long story short, I was eventually able to deduce that:
f(k,n) = f(k-1,n) + f(k,n-1) - f(k-1,n-10)
Below is a screenshot of part of part of an excel table implementing the above formula. As an example, the value highlighted in blue, f(7,12), can be seen to be equal to the value highlighted in red, f(6,12) plus the value highlighted in yellow, f(7,11) minus the value highlighted in green, f(6, 2). The two cells with the little red triangles in the corners must be initialized to 1. The cells highlighted in orange must be forced to be zero. Beyond those forced values, the formula produces all of the other correct values in the table.
With the above as an aid, I was eventually able to implement the method in a wp34s program. I have a working 63-step program on a physical wp34s that returns correct values for 9-digit numbers in about 3 seconds maximum. It could be extended to handle at least up to 11-digit arguments* within the memory confines of a wp34s, it would just run a little slower. In case it is not obvious, the method requires the current sum plus the previous 101 values to be retained in memory. I used local registers with rolling pointers to do that. (There is probably a more effective way of updating the pointers for each iteration, but I quit with what worked.) I forced the zeros required in the left-most column every 10th sum instead of calculating that sum by the formula using an inner loop. Here is the listing:
001 LBL"HHC" Comments
002 DEC X subtract 1 from target sum n
003 SDL 001 ten times (target sum -1)
004 + add number of digits to form count of iterations, C
005 STO 02 store count of iterations in 02
006 REGS 010 set number of regs to low value to free space for 102 local regs
007 #112 constant 112
008 STO A store initial r000 pointer value
009 #113 constant 113
010 STO B store initial r001 pointer value
011 #122 constant 122
012 STO C store initial r010 pointer value
013 #213 constant 213
014 STO D store initial r101 pointer value
015 #002 constant 002
016 STO 03 store initial 10 loop counter in 03
017 LocR 102 create 102 local registers
018 #001 constant 001
019 STO-> A store initial 1 in R01
020 STO .11 store initial 1 in R11
021 LBL 01
022 DSE 02 decrement iteration count, skip when zero
023 SKIP 002
024 RCL-> A Recall final sum
025 RTN finished
026 DEC A decrement r000 pointer
027 DEC B decrement r001 pointer
028 DEC C decrement r010 pointer
029 DEC D decrement r101 pointer
030 #111 constant 111
031 x=/=? A is r000 pointer not equal to 111?
032 SKIP 003 if not, skip to check r001 pointer
033 #213 if r000 pointer is equal to 111, set pointer to max local reg
034 STO A store new r000 pointer
035 SKIP 014 done updating, skip to calculate next count
036 x=/=? B is r001 pointer not equal to 111?
037 SKIP 003 if not, skip to check r011 pointer
038 #213 if r001 pointer is equal to 111, set pointer to max local reg
039 STO B store new r001 pointer
040 SKIP 009 done updating, skip to calculate next count
041 x=/=? C is r010 pointer not equal to 111?
042 SKIP 003 if not, skip to check r010 pointer
043 #213 if r010 pointer is equal to 111, set pointer to max local reg
044 STO C store new r010 pointer
045 SKIP 004 done updating, skip to calculate next count
046 x=/=D? is r101 pointer not equal to 111?
047 SKIP 002 if not, done updating, skip to calculate next count
048 #213 if r101 pointer is equal to 111, set pointer to max local reg
049 STO D store new r101 pointer
050 #010 constant 010
051 x=/=? 03 check if loop count equal 10
052 SKIP 004 if no, proceed to calculate sum
053 CLx if count is multiple of 10…
054 STO->A ...force current sum to be zero
055 STO 03 reset loop count to zero
056 SKIP 004
057 RCL->B recall r001
058 RCL+->C add r010
059 RCL- ->D subtract r101
060 STO->A store in r000
061 INC 03 increment 10 loop counter
062 GTO 01
063 END
Disclaimer - I do not claim that the above method is anything special, certainly still brute force compared to the insightful methods presented in the posts above. But since it is a different approach that produces correct results, I thought I'd go ahead and present it.
* - 10 digits would require 112 local registers, 11 digits would require 122, 12 digits would require 132, and 13 digits would require 142 local registers. The manual states that there can be up to 144 local registers created, but when I tried to extend past 11 digits, i.e., tried to enter LocR 132 or LocR 142, the instruction defaulted to LocR 013 or LocR 014. I've tried to read all instructions regarding creation and use of local registers in the manual, but have still not figured out what I am doing wrong.
Edit - saw a simple improvement to the brute force program, could not stop myself from revising it.
Edit 2 - ditto for the 2nd program, also implemented a slightly optimized routine to update the pointers. Same number of steps but should run slightly faster.
attachment=3999]
