02-16-2014, 03:53 AM
Hello a leave this simple program for calc some geometric properties
for figures made from rectangles, like W section or so.
1) first you create a Matrix
with 2 columns
col 1 is rectangle width
col 2 is de rectangle depth
for example : in Matrix M1
"I" section with
top Flange 20cm wide and 1.3cm thick
Web 0.6cm thick and 37.40 cm high
bottom Flange 20cm wide and 1.3cm thickness
(you can use more rectangles for you figure, no only 3)
2) call the program named SECTION
(the program return a list with result too. )
3) you can se some like this graphic results
4) press ENTER key and numeric result is return in a list
example:
exist some like this for Hp48, with de name iCalc from Nate Morris
but I do this version from scratch
(I do this same program for the TI Voyage 200)
thanks!
with 2 columns
"I" section with
EXPORT SECTION(mat)
Local t,d,h,y0,a,ix1,iy1,iy;
Local ssy,ry,yy1,ix,ssx,rx;
Local d1,y,i,n,at,ftor,mx1;
Local mx2,my1,my2, res;
t:= revlist(col(mat,1));
d:= revlist(col(mat,2));
t:= append(t,0); d:= append(d,0);
n:= DIM(t); n:= n(1)−1;
h:=MAKEMAT(0,n+1);
y0:=h; a:=h; ix1:=h; yy1:=h; iy1:=h;
h[1]:=0;
d1:=sum(d);
ftor:= 200/(MAX(d1,MAX(t)));
RECT_P();
LINE_P(G0,160,0,160,220,#0000FF);
LINE_P(G0,0,220,320,220,#0000FF);
FOR i FROM 1 TO n DO
h[i+1]:= h[i]+d[i];
IF t[i]≠0 THEN
my1:=iPart(210-ftor*h[i]+0.5);
my2:=iPart(210-ftor*(h[i]+d[i])+0.5);
mx1:=iPart(240-ftor*(t[i]/2)+.5);
mx2:=iPart(mx1+ftor*t[i]+.5);
LINE_P(G0,mx1,my1,mx1,my2,#FF0000);
LINE_P(G0,mx1,my2,mx2,my2,#FF0000);
LINE_P(G0,mx2,my1,mx2,my2,#FF0000);
LINE_P(G0,mx2,my1,mx1,my1,#FF0000);
y0:=h+ d/2;
a:= t .*d;
ix1:= CAS(t .* (d .^3) /12);
iy1:= CAS(d .* (t .^3) /12);
at:= sum(a);
y:= sum(a .* y0)/at;
yy1:=y0 .- y;
ix:= sum(ix1)+sum(a .* (yy1 .* yy1));
ssx:=ix/(d1-y);
rx:= √(ix/at);
iy:=sum(iy1);
ssy:= 2*iy/(max(t));
ry:= √(iy/at);
res:= MAKELIST(0,X,1,9);
res:= {"ӯ = "+round(y,2)+" cm",
"d = "+round(d1,2)+" cm",
"Ix = "+round(ix,2)+" cm⁴",
"Sx = "+round(ssx,2)+" cm³",
"rx = "+round(rx,2)+" cm",
"Iy = "+round(iy,2)+" cm⁴",
"Sy = "+round(ssy,2)+" cm³",
"ry = "+round(ry,2)+" cm",
"A = "+round(at,2)+" cm²" };
TEXTOUT_P("*** SECTION V1.2 ***",5,5,0,#0000FF);
TEXTOUT_P("by Rafael H. Padilla V.",5,21,0,#0000FF);
TEXTOUT_P("dysup@hotmail.com",5,35,0,#0000FF);
TEXTOUT_P("*** RESULTS ***",5,55,0,#0000FF);
FOR i FROM 1 TO 9 DO
TEXTOUT_P(res(i),10,58+i*16);
my1:=iPart(210-y*ftor+0.5);
FOR i FROM 1 TO 11 DO
mx1:= iPart((i-1)*10+190);
mx2:= mx1+6;
LINE_P(mx1,my1,mx2,my1,#00FF00);
TEXTOUT_P("NA",170,my1-5);
REPEAT
TEXTOUT_P("PRESS <<ENTER>> KEY",90,222,0,#FF0000);
WAIT(.35);
TEXTOUT_P("PRESS <<ENTER>> KEY",90,222,0,#FFFFFF,1000,#FFFFFF);
WAIT(.35);
UNTIL GETKEY ≠ −1;
return(res);
example:
thanks!
