09-01-2016, 12:43 AM
Pages: 1 2
09-01-2016, 01:16 AM
Hi again..
I have now:
Software version: 2016 08 29 (10637)
Hardware Version: A
CAS Version: 1.1.2-11
Serial Number: 4CY3500912
Operating System: V0.048.635
Marcel!
I have now:
Hardware Version: A
Marcel!
09-01-2016, 02:20 AM
Hi again..
My physical Prime is update but the ConnKit and the virtual Prime do not update automaticaly...
I will try again tomorrow.
Marcel
Marcel
09-01-2016, 12:34 PM
(09-01-2016 02:20 AM)Marcel Wrote: [ -> ]Hi again..
Marcel
I updated the physical calculator with no problem but the connectivity kit and virtual calculator show no updates. The FTP site doesn't have the updates either.
Tom L
09-01-2016, 07:16 PM
A system in the backend web stuff caused the files to appear early, and some old ones to show up as well. That is also why you don't see the emulator.
I suspect the files will be disappearing until the intended release date shortly.
09-01-2016, 08:14 PM
I fired up Windows 7 on Parallels on my MacBook Pro today and when I opened up the HP Connectivity Kit, I was greeted with the message that updates were available for both the Connectivity Kit and my Prime.
I agreed to perform the update, and the Connectivity Kit updated. All good.
I performed a backup on my Prime, and proceeded with the Prime update. All good.
I attached a picture of my Prime information, FYI.
smp
EDIT:
My Connectivity Kit says: Build: 2016 4 14. Rev: 10077. So, it must not have actually done any update, even though I swear it said one was available and it did two downloads and seemed to perform an update on the Connectivity Kit first.
smp
EDIT:
09-02-2016, 05:25 AM
On HP's ftp:// side I can't see anymore the new 2016-08-29 software. Only ConKit 2016-04-14, but that's also an old one.
HP what are you doing, get we the same troubles as the last 2016-04-14 updates?
09-02-2016, 10:14 AM
I don't think release 20160829 was meant as an "official public release." As such, I don't read anything, pro or con, about that release. Since r10077, the Hp folks have captured lots of issues, as mentioned in the various forums, and so I hope an "official" release will be quite an improvement! Now if they could only do something about those key legends, (for early adopters), this would become the "it" machine, for today's state of the art!
-Dale-
-Dale-
09-02-2016, 12:32 PM
(09-02-2016 10:14 AM)DrD Wrote: [ -> ]I don't think release 20160829 was meant as an "official public release."...
-Dale-
I think also it isn't an official public release. Maybe something like a RC? :-)
However, I tried to install it in two Prime's with no particular issues (in one of them I had to perform "pinhole reset" to get it working, but then all was ok).
For now this (un-official) release could be "better than none" :-)
Salvo
09-02-2016, 12:43 PM
(09-02-2016 10:14 AM)DrD Wrote: [ -> ]I don't think release 20160829 was meant as an "official public release." As such, I don't read anything, pro or con, about that release. Since r10077, the Hp folks have captured lots of issues, as mentioned in the various forums, and so I hope an "official" release will be quite an improvement! Now if they could only do something about those key legends, (for early adopters), this would become the "it" machine, for today's state of the art!
-Dale-
Second that re the key legends..
09-02-2016, 01:53 PM
(09-02-2016 05:25 AM)Dirk.nl Wrote: [ -> ]On HP's ftp:// side I can't see anymore the new 2016-08-29 software. Only ConKit 2016-04-14, but that's also an old one.
Generally, most companies release files/updates in the early part of the work week with the idea being that "if something goes wrong, the support team will be available to help customers with problems and actions to pull files can be taken should something be seriously wrong". If you push out the files/updates near the end of the week, chances increase that there is no support available due to being the weekend.
These files were published early (and only partially) for some reason. It looks like the back end system handling this has fixed the problem for now by removing the files.
09-02-2016, 02:16 PM
(09-02-2016 01:53 PM)Tim Wessman Wrote: [ -> ]These files were published early (and only partially) for some reason. It looks like the back end system handling this has fixed the problem for now by removing the files.
Hi Tim,
I get it that this "update" was probably not yet meant to be. Do you know if there is anything that I should be concerned about, since I performed the update? Should I be looking to revert to 8151?
Thanks,
smp
09-02-2016, 02:23 PM
(09-02-2016 02:16 PM)smp Wrote: [ -> ]Do you know if there is anything that I should be concerned about, since I performed the update? Should I be looking to revert to 8151?
No, and no. Enjoy it a bit early.
09-02-2016, 02:47 PM
09-02-2016, 08:07 PM
Hi Tim,
Thanks for your reply, I think I understand your answer!
So, next Monday is early in the week, I expect to see the new update again on HP's ftp side.
09-04-2016, 04:05 PM
I'll wait until the next official version to update my blog. I think the 10077 is still available.
09-05-2016, 03:14 PM
Hi all,
Can someone send me the new firmware 2016 08 29 (10637) to me.
I'm going, for my holiday, next Saturday to France. I want to update, if possible, just before that.
France, what a beautiful country, with nice people!
09-05-2016, 05:14 PM
(09-05-2016 03:14 PM)Dirk.nl Wrote: [ -> ]Hi all,
See: http://calculadorahpprime.maisforum.com/...oficial#88
09-05-2016, 07:56 PM
Hi jrozsas, thanks.
09-06-2016, 01:08 PM
The usual ftp site now has the 20160829 calculator firmware and Connectivity Kit but still no virtual calculator update.
HP Prime Firmware
Tom L
HP Prime Firmware
Tom L
Pages: 1 2
