08-30-2016, 03:46 AM
The program RPNBASIC puts the HP 71B into RPN mode with arithmetic functions, power, square root, and π. The program contains room for one independent memory and a four level stack that works like the classic Hewlett Packard RPN calculators.
I have the array S set up for six slots:
Slot 1: X stack (display)
Slot 2: Y stack
Slot 3: Z stack
Slot 4: T stack
Slot 5: Independent memory stack
Slot 6: (temporary memory)
For an idea of how RPN works, check out this tutorial: http://edspi31415.blogspot.com/2011/09/rpn-basics.html
As a note, this program requires you to press the equals key [ = ] before you enter a number to the stack.
Example: 2 + 3 + 9 = 14
Keys:
[ = ], 2, [END LINE]
[ = ], 3, [END LINE], [ + ],
[ = ], 9, [END LINE], [ + ]
The keys available during RPNBASIC:
[ = ] Input
[ + ] Add: Y + X
[ - ] Subtract: Y - X
[ * ] Multiplication: Y * X
[ / ] Divide: Y/X
[ g ] [ / ] (^) Exponent: Y^X
[ Q ] Square Root √X
[ P ] Enter π to the stack
[ M ] Store X in independent memory
[ R ] Recall memory
[ C ] Clear X stack to 0
Stack operations:
[ S ] Swap with X and Y
[ D ] Roll stack down, result { Y, T, Z, X }
Exit the program: press [ E ]
HP 71B Program: RPNBASIC (828 bytes)
Slot 2: Y stack
Slot 3: Z stack
Slot 4: T stack
Keys:
[ = ] Input
[ + ] Add: Y + X
[ / ] Divide: Y/X
[ R ] Recall memory
Stack operations:
5 ! SIMPLE RPN, EWS 8/29/2016
10 DESTROY S, K$
15 DIM K$, S(6)
20 OPTION BASE 1
25 DISP "RPN BASIC" @ WAIT 1
30 DELAY 0,0
35 DISP S(1)
40 K$=KEY$
50 IF K$="+" THEN S(6)=S(1)+S(2) @ GOTO 100
52 IF K$="-" THEN S(6)=S(2)-S(1) @ GOTO 100
54 IF K$="*" THEN S(6)=S(1)*S(2) @ GOTO 100
56 IF K$="/" THEN S(6)=S(2)/S(1) @ GOTO 100
58 IF K$="=" THEN 140
60 IF K$="M" THEN S(5)=S(1) @ GOTO 35
62 IF K$="R" THEN S(6)=S(5) @ GOTO 120
64 IF K$="P" THEN S(6)=PI @ GOTO 120
66 IF K$="C" THEN S(1)=0 @ GOTO 35
68 IF K$="S" THEN 160
70 IF K$="D" THEN 180
72 IF K$="Q" THEN S(1)=SQR(S(1)) @ GOTO 35
74 IF K$="^" THEN S(6)=S(2)^S(1) @ GOTO 100
76 IF K$="E" THEN 200 ELSE 40
100 ! 2 STACK OPERATION
105 S(1)=S(6) @ S(2)=S(3) @ S(3)=S(4)
110 GOTO 35
120 ! PI/RCL/INPUT
125 S(4)=S(3) @ S(3)=S(2) @ S(2)=S(1) @ S(2)=S(1)
130 GOTO 35
140 ! INPUT NUMBER
145 INPUT "NUMBER:";S
150 GOTO 120
160 ! SWAP
165 S(6)=S(1) @ S(1)=S(2) @ S(2)=S(6)
170 GOTO 35
180 ! ROLL
185 S(6)=S(1)
190 S(1)=S(2) @ S(2)=S(3) @ S(3)=S(4) @ S(4)=S(6)
195 GOTO 35
200 STOP
