08-19-2016, 11:52 AM
Am I overlooking a way to make the flashing entry caret a bit larger/more visible? I have poor vision and often have difficultly locating it.
Although it's usually not a big problem because I normally know where it is while editing, there are cases such as checking for syntax errors in the program editor where it's very frustrating trying to spot a single-pixel-thick caret on a screen full of code to see where my error is. (Even worse if it happens to have been placed on the very leftmost pixel column, where it can be nearly invisible.)
If not, perhaps a suggestion to the Prime developers? A thicker caret, or perhaps have the program check feature briefly highlight or flash the region where the cursor has been moved?
